Cali. How to keep the gear in N when shutting of engine? | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Klas, Apr 2, 2023.
  1. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    When shutting of the engine in N mode the DCT goes to P automatically, but if I want it to stay in neutral, how to do?
  2. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    927
    Europa
    Bob
    Carwash mode will do that, but you need to keep the key in the ignition. As soon as you remove the key it applies park.
    you can find how to activate Carwash mode in the owners manual, or search F Chat. There have been a few threads on it.
  3. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    Thanks, and no I will not wash it in an car wash, it's more about pushing the car in the garage.
  4. vjd3
    vjd3 F1 Rookie
    2,752
    Massachusetts
    Vic
    "Car wash" mode is what Ferrari calls it so the car can roll without being in park ... from the manual:
    The Park lock device can be electrically disabled on a temporary basis when the engine is switched off by performing the Carwash procedure.
    This procedure is necessary when the vehicle has to be moved with the engine off and when washing the vehicle.
    When the Park Lock device is electronically deactivated (Carwash procedure), the vehicle may move.
    The vehicle is only kept stationary by the parking brake which must be applied.
    To perform the Carwash procedure, do the following: - with the engine running, select the first gear;
    - select neutral “N”;
    - switch off the engine;
    - turn the key to position II (key-on) within 3 seconds of switching off.
    The message “Carwash mode activation” will appear on the TFT display.
    KS_California and Willl like this.
  5. mrmicks
    mrmicks Rookie
    May 11, 2016
    46
    I wondered why this popped up every now and again. Thanks!
