Cali T MCSF light | FerrariChat
Cali T MCSF light
Discussion in 'California/Portofino/Roma' started by PROV, Oct 30, 2019.
  1. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Hi all
    New to the forum and Ferrari ownership.
    I took delivery 3 weeks ago of an early 2015 California T, with 7k miles on.
    3 weeks later I have the Motor Control System Failure light on. The car runs fine and is not rev limited. Anyone else had similar and what was it if so?
    I bought from a Ferrari main dealer with 2 year warranty so hopefully should be covered. I'm based in the UK by the way.
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,887
    DFW, Texas
    Tom C
    Something like this?
    Can be a lot of things - bad battery, fuel evap system, etc. Get it dealer asap and let them sort it out. It's a good sign that is not in limp mode.
    T
  3. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Hi Tomc, yes exactly that.
    Interesting you mention the fuel evap system. The only warranty work it has had since new was on that system (the leak detection pump and the carbon cannister IIRC)..
  4. tomc
    Apr 13, 2014
    25,887
    DFW, Texas
    Tom C
    The evap system issue seems to pop up frequently. Had you gassed up the car recently before the message?
    T
  5. convertaero
    convertaero Rookie
    Mar 28, 2008
    2
    Just had the same fault come up on mine on Monday a California T 2016 with 15K miles. I am in the UK too.
    Like you no loss of power running fine.
    Put the battery on charge with a proper charger rather than the Ferrari one which I use all the time.
    Tried after battery fully recharged still came up the same. Though surprised when looking at voltmeter when engine running 14v - 15v.
    Contacted the dealer and they said better not drive it here, so they are sending Ferrari assist to pick it up this morning and take it to the dealer.
    Will post an update when the problem is resolved.
  6. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Not really that soon before... tank was about half full. I will also update
    Sent from my SM-G960F using Tapatalk
  7. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Do not ever overfill your gas tank.
    Stop filling as soon as the pump stops filling. Do not attempt to second-guess and top up your tank. Excess gasoline will enter the EVAP system. Doing so often compromises the EVAP system because it is a smog prevention (nanny) system and create a CEL forcing the driver to investigate. It can ruin the charcoal canister and result in repairs. Gas (fumes) is classed as an environmental pollutant.
    If you get a CEL or something similar to the OP’s fault warning, open the refilling flap and before touching the gas cap, smell around the refueling port. If you smell gas you may have a gas leak. Adjust the cap to make sure it is tight. Check using a OBD2 reader for a P0455 code which indicates a major EVAP leak. If you fixed the leak you can clear the code. A CEL can cause your car to reduce performance so it needs to be properly attended to.
    whatheheck and tomc like this.
  8. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    Voltage on mine when running also shows at around 14.4, so I wouldn’t get excited about that really.. the ECU light is wierd though, let us know what happens, and best of luck, hopefully it’s a £5 note in the pocket of the techie to wipe the code!
  9. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    I'd like to be able to give you an update however I dont have one.. ! Day 3 and counting
  10. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Ok so it is indeed the EVAP system. It has previously had an issue with this system so Ferrari have given them full instructions of further bits to change to try and prevent this happening again. Should be ready late next week
  11. tomc
    Apr 13, 2014
    25,887
    DFW, Texas
    Tom C
    Sounds like it is on the minor end of things that could have been wrong. Best of luck.
    T
    PROV likes this.
  12. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Got it back all spic and span. Hopefully the light will stay off now..
    tomc likes this.
  13. convertaero
    convertaero Rookie
    Mar 28, 2008
    2
    Problem solved also EVAP system leak and water in the canister.
    The dealer contacted Ferrari withe the error codes etc and Ferrari's instruction was to change all components in the EVAP system. This was done picked car up today drove it home everything ok. Hopefully thats it now and no further trouble.
    whatheheck likes this.
  14. tomc
    Apr 13, 2014
    25,887
    DFW, Texas
    Tom C
    Great. Hopefully 2 happy endings and now for more driving and less worrying! Now post up some pics of your Calis!!
    T
  15. PROV
    PROV Rookie
    Oct 30, 2019
    38
    Middlesbrough, UK
    Thread resurrection here..
    MCSF light came on again Sunday (ironically as I started the car to leave an Italian car and bike day event!).
    Anyway, same light, same behaviour (ie no restrcition on revs etc..). Car was recovered to dealer. Initial contact they are saying its not the same issue (though not sure if they mean EVAP system or just a different part of the EVAP system..
