California cam swaps. | FerrariChat
Discussion in 'Technical Q&A' started by SupercarGTM, Feb 5, 2025.
  1. SupercarGTM
    SupercarGTM Rookie
    Nov 18, 2024
    34
    Dallas TX
    I’m getting ready to replace timing chains and variators on our 2013 California 30. Since I’ll be right there at the cams it would be easy to do a performance swap. I’m thinking there are several variations of this F136 engine and stock cams are cheap at around $200 each x 4. The horsepower ratings vary per car model. Wondering if it would be worth swapping in 458 cams? I haven’t found a cam spec sheet between models but guessing that 458 cams would be more aggressive.
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,997
    socal
    I would say it depends. I have not read anything about the motor variations of cali to 458. How much is the same? If you look back at the C5Z06 corvette LS6 motor it was exactly the same motor as the base corvette LS1 motor except for cam, heads, intake manifold and engine mapping. So those 3 parts got you from LS1 to LS6. That's all easy to do with corvettes. But what about Ferrari? I think there is more to the package than cams. Cams by themselves may do nothing and in fact could make the motor not work. Motors work because they are an optimized package.
  3. SupercarGTM
    SupercarGTM Rookie
    Nov 18, 2024
    34
    Dallas TX
    That’s some of the questions I have. If it made a difference it would be any easy upgrade. btw I have a stroked LS6.
    fatbillybob likes this.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,341
    Lyon (FR)
    R. Emin
    Ferrari camshafts are normally quite optimized for a given duration, so the usual cam tweaks (grind the back of the cam) will not work. More advanced optimizations involve to match ignition. Maybe not easy on such advanced engine.
    SupercarGTM likes this.
  5. wmuno
    wmuno Formula Junior Silver Subscribed
    Dec 24, 2007
    522
    Wilmette, Illinois
    Bill Muno
    The largest knowledge base on cams in the USA is CompCams. Here’s their information:
    While a simple call to the COMP Cams® CAM HELP® tech line (1-800-999-0853) and short discussion with one of the highly informed tech line personnel will always get you the right answers, having a little personal knowledge on the topic is always a good idea.
  6. SupercarGTM
    SupercarGTM Rookie
    Nov 18, 2024
    34
    Dallas TX
    Thank you.
  7. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,766
    Lake Villa IL
    If comp cams could help with this I would be absolutely amazed.
    flash32 and Rifledriver like this.
