California Mirror Issue | FerrariChat
Discussion in 'Technical Q&A' started by sherrillt, Apr 25, 2024.
  1. sherrillt
    sherrillt Formula 3
    1,125
    Northern Virginia
    My side mirrors do not retract, but the knob still controls mirror adjustment. Any recommendation on where to start my diagnostics?
  2. Willl
    Willl Karting
    Oct 8, 2022
    163
    Vancouver, WA
    Will
    I believe the California side mirrors are manual retract only, no power option
  3. sherrillt
    sherrillt Formula 3
    1,125
    Northern Virginia
    No, if you turn your knob on the mirror control to the -><- symbol (which is retract) located at the 6 o'oclock position they should retract.
  4. Willl
    Willl Karting
    Oct 8, 2022
    163
    Vancouver, WA
    Will
    Guess I'm heading to the garage :)
  5. Willl
    Willl Karting
    Oct 8, 2022
    163
    Vancouver, WA
    Will
    You are correct sherrillt, the California does have power retractable side mirrors :D
    Did not know that, thanks
    What other secrets are you hiding?
    Round 1
    Check fuses, scan for codes, if no codes then remove mirror switch, check for continuity and power or hard electrical reset at the battery, which ever one is easier first
