News
California Radiator Poor Design
Discussion in 'California/Portofino' started by Mark Hamister, May 16, 2018.
  1. Mark Hamister
    Mark Hamister Rookie
    May 16, 2018
    1
    Mark E. Hamister
    I was shocked recently to learn that the Ferrari California radiator can be damaged beyond repair by a small road stone. then to add insult to injury it costs about $4K to replace the radiator due to the poor design of not only the failure to provide screening for the radiator but the need to remove the entire bumper assembly to get at the radiator. All of this allegedly not covered by warranty. Has anyone else had a similar experience?
  2. Shotgun Styles
    Shotgun Styles Formula Junior
    Apr 11, 2018
    295
    Shotgun Styles
    I have never understood why cheap cars are so durable and expensive ones are so delicate.
    You can beat the hell out of a Camaro or a Vette, and they just take it. If you don't perfectly service your Ferrari or Lambo, you end up with a 5 figure fix on your hands.
  3. good2go
    good2go Formula Junior
    912
    Minneapolis
    No issues with my California T. I have over 14k miles.
  4. wrs
    wrs Formula 3
    Rossa Subscribed Owner
    Jul 11, 2015
    2,064
    Austin, Texas
    William
    Definitely an issue on the 991tts. Solution was to get a metal grid to fit in the nose.
  5. 4th_gear
    4th_gear F1 Rookie
    3,832
    Michael
    Small stones destroy metal radiators all the time. It's not peculiar to Ferraris. They are all expensive to service. You can get someone to add a mesh behind your car's grill but that will likely interfere with the cooling. There's also the optional GTO style grill from Ferrari, not mesh-level fine but finer than the regular grill. Expensive.
    Many high end cars also used plastic radiators and those tend to catastrophically self-destruct (blow up) on a regular basis and can also destroy your engine if it happens at highway speeds when you cannot immediately stop the car.
  6. 4th_gear
    4th_gear F1 Rookie
    3,832
    Michael
    Nothing complicated. If you want high end performance and exclusivity, you pay for it. That's why they're exclusive.
    Exotic high performance cars usually use components that are custom-designed for that one model and only a few thousand cars are made. Cars like Camaros and Vettes (even 911s) use many standard time-tested components shared with older cars and other car models made in the 100s of thousands if not millions.
    Even BMWs require strict adherence to service schedules and some people try to turn off service reminders. I'm not being flippant but if you can't afford to adhere required service requirements, then you can't afford to own the car. These cars come with serious after-purchase expense commitments. Ferrari's 7-year free service lure owners who lease and return their cars so those cars can end up with owners who cannot afford non-warranty repairs.
    At any rate the Cali radiator is actually $1,350 and the $4k bill may be inflated.
    AlfistaPortoghese and timjen88 like this.
  7. Redneck Slim
    Redneck Slim Formula Junior
    434
    Palo Alto,CA,USA
    Walt Kimball
    Sixteen years driving my 2002 Corvette,and the total repair costs wouldn't even pay for a fire extinguisher for my Portofino.
    Shotgun Styles likes this.
  8. tomc
    tomc F1 World Champ
    Apr 13, 2014
    13,699
    DFW, Texas
    Tom C
    Wow, less than $1100?!? I'm assuming that excludes scheduled maintenance, tires, etc. That's reliable. Even our Honda Ridgeline has cost us more than a grand in repairs.
    T
  9. Redneck Slim
    434
    Palo Alto,CA,USA
    Walt Kimball
    That is just replacing the few things that broke. But routine maintenance is low because I do it myself and because GM sells a comprehensive service manual. Sticky tires are the biggest expense. Other than those tires,it's just a Chevy.
  10. tomc
    tomc F1 World Champ
    Apr 13, 2014
    13,699
    DFW, Texas
    Tom C
    4th...Never seen that mesh grill before. Cool. Have thought about the mesh for my 911 as it accumulates a ton of crud in there. I have to clean it out once or twice a year. My worry is that with our warm weather, it'll retard cooling to some extent...T
