California top and trunk issues please help!!!! | FerrariChat
Discussion in 'California/Portofino/Roma' started by Aaron smith, Feb 8, 2019.
  1. Aaron smith
    Aaron smith Rookie
    Feb 8, 2019
    5
    Aaron Smith
    I just purchased a 2010 California at Barrett Jackson after a few too many drinks. At the auction the top was down then for some reason reliable carriers then shipped the car with the top down. We got the car off the truck and put the top up. It seemed to work properly. Then today I go to put the top down and if stops halfway through and says something like top malfunction ( I don’t remember exactly what it said) it would still let me close the top from this position so i did. I then did the manual reboot unhook the battery lock then unlock the doors and start the car. Now the top went down with no problems. I felt like a genius. Then i go to put the top up and it goes halfway up. It starts spraying hydro fluid but then continues to go up. It eventually closes (we’ll almost) now the dash says complete roof close or something like that and it WILL NOT move anymore in either direction. The worst part is the truck will not Open either. Not with the key fob or using the key in the manual trunk release. Now I can’t even see what is going on I would think priority one would be to get the trunk open to be able to find the leak and repair or possibly fill back up with fluid. But nothing i do will make the trunk open. Please help me
  2. Aaron smith
    Aaron smith Rookie
    Feb 8, 2019
    5
    Aaron Smith
    I have searched all the threads here and nothing is working. Has anyone else had this problem and not posted about it
  3. Alcav5
    Alcav5 F1 Rookie
    4,073
    Scarsdale, NY
    Al
    there are posts , maybe not same thread title as yours but definitely same posts.
    I had similar problems w my 2010, all i could say is don't you fool w top until it is corrected. I kept playing w it and the top eventually dropped down on itself and dented the metal where it dropped.
    I was told my issue was low or leaking fluid.
  4. biotequity
    biotequity Rookie
    Jun 22, 2012
    18
    New York City
    Michael Taylor
    “Spraying hydro fluid” - i think that might be the problem?
  5. Aaron smith
    Aaron smith Rookie
    Feb 8, 2019
    5
    Aaron Smith
    The problem is now the top is up and the trunk won’t open. So I can’t do anything about the fluid. I need to get the trunk open
  6. SVCalifornia
    SVCalifornia F1 Rookie
    2,563
    Silicon Valley
    Keith
    Couple of things to try.
    First. Hold the key fob with both unlock button and the open trunk button at the same time for 10s. It can force the trunk to open if it can. (I think that is the right combo, or door lock and trunk open).
    Second. Key unlock in the trunk only works if you release the pressure from the lock of the trunk to the chassis. Try pushing down on the trunk while you turn the key in the trunk release.
    SV
  7. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    There may be some useful info in this thread.
    https://www.ferrarichat.com/forum/threads/whoops-help.351555/
    As to point #2 in the preceding post, when I've had issues with the trunk release, I find it best to have someone else push down the trunk while the second person turns the key.
    Probably dumb question, but have you tried the trunk release button on the floor on the driver's side?
    T
