Caliper piston spreader tool from Girodisc | FerrariChat
Discussion in 'Technical Q&A' started by velocityengineer, Mar 14, 2007.
  1. velocityengineer
    velocityengineer Formula Junior
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    #1 velocityengineer, Mar 14, 2007
    Check it out guys, if youve ever had to change pads or work on multi piston calipers, you will want to see this! No more pliers and screwdrivers!
    Girodisc Announce the Caliper Piston Spreader Tool for 4 and 6 Piston Calipers
    Costa Mesa, CA – April 19, 2005 – Girodisc announces its Caliper piston Spreader.
    This indispensable tool is designed for use by race teams and enthusiasts alike who have high performance 4 and 6 or 8 piston calipers. The spreader is designed to spread the pads - and then the pistons in 4 and 6 piston calipers to facilitate quick replacement of pads and rotors in a shop or racing environment.
    No more screwdrivers, pliers, or hammers. This tool will retract the pistons evenly and all the way back into the bores with one squeeze of the levers.
    The Spreader was designed around the popular Porsche 4 piston and GT2/3 6 piston calipers as well as most 4 piston Brembo, AP, Alcon, and other performance calipers in racing and road use. To help fit in any caliper, the amount of throw is adjustable through three settings of the outside plate.
    Insert the spreading plates one way for wider 6 or 8 piston calipers, and then turn the unit 90 degrees and use the plate sides for 4 piston calipers. One corner will angle into 2 piston opposed calipers also.
    The tool is made from steel and is powder coated for durability. The slider is cadmium plated. The pivot bushings are all made from nylon and will ensure smooth action.
    This tool will quickly become invaluable to any team, shop, or enthusiast who changes pads and rotors with any frequency.
    To find out more, contact Girodisc at (949) 350-6194 or email info@************. More information is available on the web site: www.************.
  2. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Very nice! This will be very handy at track days when you want to swap out your street pads for track pads.
  3. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    Almost as fancy looking as the brakes they're used on...that's pretty cool. Eric, is that a picture of you in the back of a Countach? Good stuff, man.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Looks like it'll take up a lot of room in the drawer. I use a $10 "C" clamp, works fine.
