Caliper piston spreader | FerrariChat
Discussion in 'Technical Q&A' started by velocityengineer, Apr 19, 2005.
  1. velocityengineer
    velocityengineer Formula Junior
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    Hi guys,
    Yet another new product press release.
    We have been busy.
    This one is a pad and piston spreader for opposed piston and multi piston calipers. This is a tool you wont want to live without if you ever service multi piston calipers. It will spread the pads to remove them and then the pistons evenly into the bores. No more scratching up your calipers with pliers and what ever tools we have all tried to use to do this frustrating job.
    Have a look at the pdf for the piece.
    -Eric
    View attachment PRESS RELEASE CALIPER SPREADER TOOL.pdf
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    EXCELLENT!!
    I could use one of those. Cost?
  3. velocityengineer
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    Hiya,
    The retail price is $200.
    We are open to a ferrarichat member group buy as well.
    We have sold out the first production run faster than we expected, and the next run is happening right now.
    Stay in touch and youll be first in line for one.
    -Eric
  4. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    That's a steal.
    I want.
  5. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    How am I going to squeze that plate between the disk and brake pad w/o spreading it apart first with a screwdriver?
  6. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    You use the tool after you've removed the caliper from the disc.
    I just use a C-clamp with a ground down arm so it fits in between the pads. Put a block of wood on the outside, Compress the pistons one side, then switch the clamp & block over & compress the pistons on the other side.
    Hmm, think I also saw a spreading kit in the tools that AZ loans out.
    However, if I were doing this on a regular basis, this tool sure looks easy/quick to use... Would increase productivity.
  7. Martin Meade
    Martin Meade Karting BANNED
    Oct 25, 2004
    229
    B'ham, WA
    Martin Meade
    The tool is originally designed specifically for racing, for use in the pits with quick pad changes during endurance events. It also makes it handy as a shop tool.
    First you place the corners of the spreader between the pads in the caliper and spread them. The pads will then come out super easy.
    Then, without pads, there is plenty of space where the pads were between the rotor and pistons. Just slide it in and squeeze.
    No need to remove the caliper at all.
    Ill send pics of it in action asap.
    Eric
  8. Martin Meade
    Oct 25, 2004
    229
    B'ham, WA
    Martin Meade
    Here are two promised pics of the spreader in action on the workbench.
    The job is the same on car to change pads, no need to remove the caliper. On car, the rotor would still be in place, but the spreader flanges go in-between the pistons and rotor.
    The pics show how the pads are spread to loosen them initially. Once the pads are removed, just inset and spread all the pistons evenly back into the bores and insert new pads.
    Simple
    martin
