Caliper pistons stuck | FerrariChat
Discussion in 'Boxers/TR/M' started by qwazipsycho, Dec 27, 2016.
  1. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    Aloha, it's been a while.
    So, I finally decided to tear into my front brakes and see why they are hanging up so bad.
    Anybody have any thoughts on how to remove stuck rusty caliper pistons? I got one out of 4 out but I'm afraid of damaging the others. They are rusty and stuck.
    Also, I've been trying to get a hold of someone at Girodisc but they don't answer their phone or emails. Any other suppliers out there with reasonably prices rebuild kits?
  2. Rifledriver
    37,089
    Screw a grease gun into the brake hose fitting. Use "C" clamps to control the ones that move easiest until they are all nearly out.
    Or just send them in one piece to whoever is going to rebuild them.
  3. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    Good idea. I'm doing the rebuild so grease gun it is.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    good idea brian, I also do so sometimes, but before I aways try to push the brake pedal to get the pistons out a little, then I block those what are moving and when all have been moved normaly it is easy then to take them out
    nice to hear again from you scott with doing work on your car:)
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    I have always had luck with an air hose at 125 PSI. But, those pistons were not rusted. Grease guns would work.
  6. Rifledriver
    37,089
    Smashed fingers, damaged pistons and brake fluid everywhere.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Remove the outer seals and soak them in a vinegar bath for a few days.
  8. Steve Magnusson
    26,783
    That's on my list for one of the many reasons that I'd just have PMB restore them ;) A lot of things don't add up when maintaining a F, but I can't fault the PMB value proposition - JMO...
  9. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Greetings. Patience and use the grease gun. When I rebuilt mine I used air and Brian is right minus the damage to the piston. Rebuild them yourself. Girodisc rebuild kits are good because they include the small o ring washer so you can split the caliper once you have the pistons out. I cleaned the outside with wire wheel brush They came like new. Pistons and piston wall I used scuff pads. I found a scuff pad that was round and I used my dremel to clean out and polish the pistons and piston wall. There is a groove inside the piston wall that is tedious to clean. A large round o ring is seated in that groove so cleaning it up properly is very very important. The only real pain in the ass is placing the dust seals in place with the ring clamp. The girodisc ones are ****ty. Try and be careful when taking off the existing ring clamps. I reused them as I thought that they were better quality. Again take your time brother and you'll get great results. Do not clean pistons or piston walls with wire brush. You do not want to remove any piston or piston wall material. Wire wheel is for the exterior of caliper only.
    R
  10. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    ...including in your mouth up your nose in your eyes ears and hair. I'm so glad I don't do this for a living anymore.
    FLASHBACK! The very first day of my very first "professional" mechanic job. I was 16 years old. Aamco Tranmsissions R&R line tech. I walked home drenched in burnt ATF. I would later find the only worse smell I would encounter in that line of work is burnt gear lube. Nauseating.
    Well, thanks for that little piece of mental nostalgia.
  11. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    Forgive my ignorance Steve. PMB???
  12. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    Have you been in touch with Girodisc lately? I can't get a response out of them.
  13. yelcab
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Well, you put a piece of wood inside the caliper first.
  14. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #14 166&456, Dec 28, 2016
    Totally agree. Compressed air is NOT a good idea. If flying pistons while crushing fingers weren't already bad, breathing the resulting brake fluid mist once it pops is also a very, very bad idea for your lungs. Picking up smoking is a lot more favorable in comparison.
    IWhile grease will most certainly work, I am not a big fan of using that, bit of a mess and the difficulty to get rid of it from the canals of the caliper (and you have to to avoid future seal damage). Using the hydraulic pressure of the braking system pumping with your foot or a bench device made with an old clutch master cylinder making hydraulic pressure are better in my opinion.
    Or indeed, bring them to a brake specialist. Much less hassle and risk, plus you usually get new paint or zinc coating and a warranty.
  15. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,665
    Argent/Brasil
    Guido
    Normal grease will eat rubber seals..so when rest of grease is hidden in almost impossible places, you have leaking seals in no time. Suggest using brake grease instead when using a grease gun.
    Guido
  16. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    I was just about to write similar advice.
    Compressed air is very good, you can do it neatly by hand tight normal air coupling to caliper and nylon tube between coupling and blow gun, very neat, does not spary fluid.
    Last summer I did old Mercedes that uses similar calipers, they where so tight that eventually I filled caliper with water and sledge hammered to one side piston, it also works.
    Issue was old grease that simply held piston down and it came through seal and splitted seal half. Clean, new seals and still using same parts, after all they where 40-years old.
  17. Steve Magnusson
    26,783
    Maybe I've spoken too quickly as they don't specifically list TR, but the first time PMB posted a picture of a rebuilt (really restored), replated (including the fasteners) 308 rear caliper with new Welch plugs here for a few hundred $s a pair I thought to myself "wow, you couldn't do that yourself for less - what good value". Maybe worth a call/email:
    PMB - Ferrari Brakes
  18. Rifledriver
    37,089
    Exactly
  19. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    #19 302Tim, Dec 28, 2016
  20. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    As always, a wealth of information and a few laughs. Thanks Gentlemen.
  21. Rifledriver
    37,089
    By the way, everyone who answered with air has never encountered a stuck piston. 175lbs of air will not do the job. Grease is how the people in the rebuilding industry do it.
  22. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    #22 ozziindaus, Dec 28, 2016
    Correct, TR is not listed and it's not the same price as 308 or 512. I got charged around $780 complete and it was definitely worth it since all but one of my pistons were seized enough to give me a headache. They even threw in some original bleeders because the aftermarket ones they originally sent were way too long for my liking sooooooooo, be careful removing your bleeders because they are hard to find. Anyway, highly recommend PMB.
  23. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    I still haven't heard anyone say a word about the fact that Girodisc is M.I.A.
    Anybody?
  24. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    scott:
    what is M.I.A.?
  25. qwazipsycho
    Oct 30, 2004
    1,176
    Utah
    Scott
    Missing In Action
