Ok, so here is the backstory. You all know that we picked up the red '97 GTS a couple of months ago. It's been trouble free. We drove it about 300 miles after it got to AZ off the trailer. Then put in a new battery and tender. Got emissions done, and it passed after adding a new cat. Then drove it another 300 miles. You have hopefully seen the threads I've been posting. It's probably been started, driven, locked, parked, unlocked and repeated around 30 times since it arrived. The car only came with one original fob and key. Rather than use the existing sealed pin code to get new fob's ordered from Ferrari, (where I have read some stories of unorganized mistakes happening) and incurring a 5-8 week delay or even more costs, I opted to take f-chatter "Gobble" (Mark) up on his offer to have the one good fob cloned to two new ones so we would be able to keep the pin code original and just add two new cloned fob's for backup. I sent the original fob and an extra purchased one off to Mark and he was very quick, accommodating, and helpful in getting the original and 2 new cloned fob's back to me within a day. I've been very happy to find his service and was looking forward to having this done and going to order 2 extra keys from the dealership afterward. But as can happen, this did not go to plan... I went into the garage with the 3 fob's to check and see that each worked. The battery tender was plugged into the rear. I tried the original 5 or 6 cycles of pushing the button to hear the doors lock and unlock and the lights to blink that the car was good to go. All went well. Then I picked up the second fob and pushed the button. The alarm immediately went off with the lights blinking. What a horrible noise that thing makes... I hit the fob button again to try to turn off the alarm. It didn't work. Pushing that button would not unlock doors or do anything else. The light on the fob would light up but it did not have any other function. So I'm in the enclosed garage with the crazy loud noise and no luck. I picked up the original fob and clicked it. The doors would actually lock and unlock, but the alarm would not shut off. I put the key in the ignition and the car fully started up. I did that successfully twice, and then decided it was time to hit the master battery switch off. I popped the hood, turned the master switch off, and waited for the alarm to stop. It did stop after about 10 more seconds. Because the battery tender was plugged into the back, there was a whirring sound from between the engine and the cab - that must have had something to do with the alarm still trying to operate... So I unplugged the tender and the whirring sound stopped. I turned the master battery back on - and the alarm picked back up in all its glory. So I wasn't feeling very good. It was not a fun situation. None of the fob's would stop the alarm. But the original fob would unlock and lock the doors and allow me to start the engine. I had a lot of business to take care of so shelved trying to fix this until Friday... I called Mark to explain what problem that I encountered using one of the new fob's. Here are his suggestions from him and he also checked in with TAZ. We could not find any posts with similar circumstances... "In 2012 there was a guy called Texas Turbo that had the same problem. I'm reading the message he said he held down the button on the original until the lights stopped flashing. He then says he pressed the button 47 times on one new fob and 32 on the other to get them in sync. All was well after that. His message said he thought it was caused by a weak battery but he wasn't sure. The only thing Taz can think of is that maybe the car saw a rolling code that it's already seen before and that triggered the alarm. He says press the button a few times and see if that fixes the issue. We're stumped on this one. Nothing comes to mind other than I cant see how a remote would set off the alarm and then not shut it off. If it's a rolling code thing maybe try pressing the buttons on both remotes until it goes off? It's possible using the new one got the old one out of sync and it needs to catch up with a few presses?" So I post his thoughts looking for more help from the group. I'm happy with Mark and his response. I'm not trying to dog him. My goal is obviously to STOP the alarm first, then be able to use the original fob to get back to normal. Second goal is to be able to use the new fobs successfully although they will likely be used mainly as backups. DaveRocks advised me against going with cloning but I thought I would get lucky based on how many success stories there have been with Mark's services. I had not read of any problems. I hope this is easily fixible. So can anyone out there help me understand what the problem is and why the original fob can work correctly on the doors and ignition but not be able to turn off the alarm? I will replace all 3 fob batteries before attempting to use them again but they do light up when pressed. Please help a brother out! And I will follow step by step instructions if people know what to do. I would much rather do that than "wing it and see what works." I doubt turning the key to enter the pin manually will work because the original fob and key already work properly with the locks and ignition. I think my '95 just rose in value today... Robb Image Unavailable, Please Login
Don't panic rob. A clone is a fine alternative. 100's if not thousands have been done and for years. Cloning is a great option to spending big bucks with Ferrari. The Fob has dual function. It has the typical on/off arm/disarm feature of any alarm and then a panic mode. They are 2 separate functions. If you hold the fob button down for 3 sec you enter this mode and everything rings as you describe and you can use the fob for the other on/off arm/disarm features as you discovered and drive your car with the panic mode blaring. Turn off panic mode by holding down the fob button again for 3 seconds. Problem solved. You may have to use your red remote or the original remote not the clone if the clone is not synched. A clone is a clone and must be synched with the rolling code the master is counting off. If you use your clone is 6 months you will have to press it "x" times to resynch. If you use your clone in 1 year you will have to press it "x+more" to synch it again. The problem is when people try to synch clones they sometimes hold the button not press it and enter panic mode.
Had a few cloned myself I do remember a couple took some time to sync. Use the same fob all the time to avoid rolling codes, one of my backups took 20 + clicks before hitting then worked like a charm, been using it 2 years now no issues Moral of the story use 1 fob all the time
Ok Carl. I wasn't even aware it had a panic mode but it makes sense. Great to learn. I will try to hold down the original to get it back to normal without the alarm. After that succeeds, do I just click through a number of times with the new fob til they sync? Hopefully I don't have to demonstrate this at the stooge fest... Thanks. Robb.
I agree and will plan to use 1 all the time. But I do still want the other two to work. I guess it will be a click fest. Robb
It sounds like holding down the button on the original would be consistent with how TexasTurbo solved the issue. As I mentioned I'm otherwise stumped and I've been doing these for almost 5 years. Cross my fingers. And to add to the post above I think you want to hold down the button on your black original, not the new red one.
I was too tired to mess with it until tomorrow. But I am looking forward to success. I wish there was a "standard" number of times to click to get these to sync. Thanks Mark. Robb
Robb- Here is a Ferrari alarm manual for you to read through. I had actually forgotten about the panic mode since I had never activated it. Did you actually hold the button down for three seconds on the clone, or did it just do it on the first depression? If you just depressed it normally, it should not have activated the alarm. Be advised clones work best if you more or less use them on alternate days with the original fob. This keeps the rolling codes close enough so that only a few button depressions are necessary to find a rolling code the Alarm ECU has not seen before. A bit of a pain, but better than pulling out a clone 2 years from now when your original fails and having to depress the button 500 times to find a new rolling code the ECU likes. There are 67,600 possible rolling codes, so you are not going to get all the way around. Those fobs bring good money by themselves, so if you ever decide you want a full set, that is always an option. Risk is lessened by using your old PIN you are lucky enough to have and starting the engine using just the PIN and key. That proves you have the correct PIN When you get a new set, they come with a new PIN, so you would be set. Here is how to start the engine with the PIN. Image Unavailable, Please Login Image Unavailable, Please Login
Taz, Thank you for your input. I didn't hold any fob button for more than one click, but weirder things have happened I guess. How's this sound? I'll try to get the alarm and general operation back to normal with the original fob. And then will wait a day and will use a different fob. I'll plan on clicking that until it works correctly with that fob. However many single clicks it takes. Then would I go back to the original fob the next day or the third fob? Once I get all three fob's to work, I planned to just store two of them. Thoughts Taz? Robb
I haven't made my way over to get this sorted out yet. Hopefully around lunch time. But I'm still not understanding the normal hoops I will have to jump through to be able to pick up any fob I want and go drive the car. Because that was the goal. I thought cloning the original fob would give me three copies that worked the same way every day. If the car forgets the other two fobs regularly, I don't want to have to stand there clicking the fob 50 times before it hooks up. I originally bought the extra red fob just for the outer plastic colored shell to swap to the new fobs bought from Ferrari. If this becomes a pain in the ass after this... I may just go back to that route and pay Ferrari for the 3 fobs - lesson learned. Robb
I've had a clone done by Gobble for my car for about 2 years now and it has worked great. It's not too big of a deal to get them synced. It is just on the first start up each time you switch fobs. I switch back and forth regularly and I still swear I have to push the button 100 times to get sync for the first time. but that is just a minute in the garage and then once it is synced that fob works first time every time for the rest of the day/weekend/ whatever until you switch to another fob. Its the price you pay for not paying the price of new fobs.
We'll see how it goes. I did not read anywhere about this hassle in sync'ing or becoming a manager of fobs in my spare time. So I'm leaning toward having my brother pay Ferrari for the 3 new fobs and moving on. First step is to make sure I can just get the alarm to stop once I turn the battery on and I'll go from there. Robb
Robb My experience has been that if you use one remote once, the others need to be pressed once to catch up. If you press one remote twice, the others need to be pressed twice to catch up. You get the picture. When I bought my 360 I had a single remote. I only used one remote, but I could sleep better at night knowing I had another in the drawer should something happen to my original. If I used the original for two years and lost it, pressing the button a few hundred times to catch up the spare was a better option then writing a $1,000 check ($1500 if you don't have a pin). My car arrives at 2:00 today and I've had thoughts of selling one of the three remotes to offset the purchase by $200. I don't feel I need three of them.
Agreed! Gobble and Eric355 have given every owner since the 5.2 motronic an alternative to buying expensive 3 new remotes and an new alarm ecu and having to swap burned in Motronic ECUs. If is "better" to go the all Ferrari way? Yes. Does it matter? Probably not. Most will use 1 fob all the time. The other fob's clones or not are back ups. This is really not a problem at all especially if the Ferrari is driven like most Ferraris low miles.
Maybe your original pin is incorrect? If you want to clone one and sell the other two I'm sure we can work something out. Or sell them to Robb?
That's a whole other issue trying to get the new stuff to mate with the old even if you spent all the money to do it the best way. The reprogram on the surface is easy but it is anything but. I would rather pull your motor, change your belts, and cam time your motor than figure out Ferraris clearly simple process for refitting a new alarm kit that never seems to work. Gobble and Eric355 saved many of us the pain of having to deal with yet another Ferrari issue.
I'm starting to understand how they work and what is needed to use the cloned fobs. Is it a value? Absolutely. It does save money and gives you backups in case of a loss or in case you do not have the original pin. But since I have the original pin, this might not be for me over the long run. Looking forward to seeing what I find at lunch. Wish there was a set of directions for this whole process of using cloned fobs. Maybe someone can write that up and put as a sticky so others don't do what I did. Robb
My '95 Berlinetta is so "easy" that I doubt I would ever consider buying a '96 to '99 ever again... Robb
Robb it sounds like you're very particular about your cars and that's great. When I'm in the market for a car I look for one that's owned by someone like you. If I were you, and I'm not, I'd sell one, cash out $200, keep one in your pocket and the other safely in a drawer. If you ever lose the original you have a backup. If you ever lose both I have your data saved and can make an unlimited number of additional backups. You'll never have an expensive fob problem. If it's important to you to have one red fob and two black fobs (and I think the new sets come with 3 blacks) that all sync perfectly and multiple people in your family handle remotes and use the car maybe you're better off spending the $$$ and hope the factory route works. If you don't like the clone I'd be happy to take it back.
Just saw this on tv and it made me laugh: "If you think you're having a bad day, at least you've never been on COPS. Tonight at 7." That's true... I don't want to be in that show. Lol. I haven't had any bad days even since the alarm first started going off. Life is good and I'm happy. Glad to understand the issues and options. Robb
I wasn't aware that a cloned fob would work any differently than a "factory" fob- it there some reason the cloned black fob can't do what a factory black fob can do, or do the factory fobs also need to be re-synched after a period of time? I never noticed any issue like this using the factory fobs on my 360...I essentially used one black fob 99.99% of the time for the 5 years I owned it.. and didn't notice any difference the 1-2 times I used the other black fob. I'm sorry if this question is too off-topic from Robb's question- I don't want to hijack the post, but the 355 I just bought is also yellow so I figured yellow 355s all operate the same Once I actually get my car in a couple of weeks, one of the first things I will do is get the single remote the car is coming with cloned by Gobble- he really knows his stuff!
Andrew, not off topic, I wasn't aware of this either. Hence my current situation. I did not realize you needed to stagger uses when first trying out the cloned fobs or the proper way to "introduce" them to your car. Mark is smart. No doubt. The cloned fobs may or may not be my final choice since the car does have an original pin... And just so you know - my yellow car is a '95 Berlinetta without the fobs. My brother's car is the red '97 GTS with the fobs. The yellow is faster... lol since it starts right up. It has a head start. Robb
