cam belt change | FerrariChat
cam belt change
Discussion in '348/355' started by jeff11110, Jan 7, 2010.
  1. jeff11110
    jeff11110 Rookie
    Jul 17, 2005
    16
    my 348 has now done 50,000 miles has had 4 cam belt changes when i bought it 5 years ago ive done 18,000 miles since the last change [5 years ago], im paranoid about changing them soon, but surely at 18000 they or it should be ok, whats the verdict on ferrari owners out there
  2. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    #2 DonJuan348, Jan 7, 2010
    as the Cali gurus told me... 5yrs is fine as long as you dont track the car. mileage wise about 25k .
    Since its been 5 yrs I would change them. then go another 5 years
  3. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    From what I have read here in the past, it seems several guys use the 5-year interval.
  4. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    It's time for a change. I changed mine at the 4 year mark but will be going to a 5 year schedule from now on.
  5. jmiff348
    jmiff348 Formula 3
    2,369
    Texas, USA
    Jarrett
    #5 jmiff348, Jan 7, 2010
    Jeff, I just had my 348 belt changed last week. Although it could have probably gone a lot farther, it was starting to show some signs of wear at 15,000 miles. Be sure to change the tensioner and idler bearings while the engine is out. My tensioner was on its last leg (the belt was very loose/floppy on the right side of the engine - above the tensioner). I went with Hill Engineering bearings (from Ricambi) and saved several hundred $$ vs OEM.
  6. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Not just the cost savings, but from what I understand the Hill Eng bearings are far superior to the OEM
  7. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    +1
  8. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Does anyone know exactly how they are superior to OEM?
  9. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Hill Engineering use a better bearing than OEM Ferrari. ;);)
  10. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    #10 sambomydog, Jan 7, 2010
    Yes quite. What i would like are specifics on the said bearing. I am assuming that Ferrari still use SKF bearings, as they did/do from F1 cars to there road cars. Again i am assuming that SKF are/were a reputable bearing company of quality who have had a long relationship with Ferrari. http://www.skf.com/files/349730.pdf http://www.skf.com/portal/skf/home/products?newlink=first&lang=en
    So what type of bearing does Hills use? What make?
    For the record i have been using Pauls bearings my self for 5 years. But i have never really gone into why his bearings are better than the SKFs.
  11. Ricambi America
    Sponsor Owner
    #11 Ricambi America, Jan 7, 2010
    In the most general terms: higher temperature grease specs, different bearing itself, hard outer shells, load rating of 17k newtons vs. 11k newtons. 128 gram carrier weight for Hill vs. 220 gram carrier weight for OEM.
  12. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Sounds like a killer bearing!! :D:D
  13. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Jeff, my opinion is that doing an engine-out service to change belts makes it a lot easier to check and do other things that should also be done... such as checking the tensioner bearings, cam seals, valve adjustment, etc. etc. It just provides an opportunity to check and verify lots of other things.
    Besides that, I suppose you could say a properly-installed new belt is less likely to fail than a 5yr old belt. The belt is all about how much risk you're willing to accept by not changing them. I prefer the 4-5 yr. program myself.
  14. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    MMMM, lose belt .... very scary, can't wait to do mine.
  15. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Don't you love it when Daniel talks sexy?? :)
  16. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Now thats the kind of answer i was hoping to get, thankyou for the answer:)
  17. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    #17 mike_747, Jan 10, 2010
    Ok I get the sense that the Hill bearing is superior to the Ferrari bearing.
    As an aerospace engineer and not a mechanical engineer, can someone please explain why the Hill unit with a lighter carrier weight is better that the Ferrari unit with a heavier carrier weight. I'm interpreting the carrier to be the inner and outer races of the bearing - maybe I'm all wet here?
    So, from a durability standpoint I would think that the heavier unit would be more robust and durable. what am I missing here?
    I did see where the Hill unit can handle a higher load - so this is good and a "no brainer".
    thanks for the education. I'll be ordering the Hill bearings and saving $800/pair over the Ferrari bearings. By just using OP (other people's) plugs, plug wires and belt tensioners I'll save $2,500 over the Ferrari Dealer price's while doing my major service!!
  18. 348paul
    348paul Formula 3
    Dec 27, 2002
    1,098
    Kent - UK
    Paul Hill
    Reducing rotational mass - A heavier carrier would only add to the moment of inertia which is something we would always try to reduce without affecting the integrity of the design.
    Many thanks
    Paul
  19. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    isnt moment of inertia a property related to bending? how does it related to spinning of a bearing or loading due to eccentricity (in the case of said bearing)? i can see how reducing mass is good in this application, but not related to moment of inertia, but then again i slept through engineering school.
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Pfffft, what would you know!! :eek::eek:
  21. 348paul
    348paul Formula 3
    Dec 27, 2002
    1,098
    Kent - UK
    Paul Hill
    http://www.engineeringtoolbox.com/moment-inertia-torque-d_913.html
    Moment of Inertia (Mass Moment of Inertia) - I - is a measure of an object's resistance to changes in rotation direction. Moment of Inertia has the same relationship to angular acceleration as mass has to linear acceleration.
  22. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    i was thinking of the area moment of inertia, which relates to bending moment
