CAM BELT CHANGE | Page 2 | FerrariChat
CAM BELT CHANGE
Discussion in '308/328' started by steve meltzer, Jun 18, 2025.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    "Comfort Level" is, IMO, the practical timeframe for belt/bearing replacement! Clearly, there are folks "comfortable" with every two-three years and there are those "comfortable" with far longer time frames. New belts were installed by the seller's shop a few days before I drove away with my "new" 328 in Aug, '08. I've replaced the belts/bearings three times since then -roughly 5 year intervals. If you were to ask me if I thought they were due for replacement on examining the used belts/bearings during any of the changes, I'd say, "No." But my comfort level is five years (give or take a bit).
    ggjjr and ChevyDave like this.
  2. lopena
    lopena Formula Junior
    766
    I use Hill bearings and Dayco belts and replace them every 6-7 years…been doing this on my 328 for 32 years.
    I change the oil every 18 months and replace the filter every other oil change.
    I have 6 cars to maintain so doing it any more frequently would drive me to drink (more).
    Alan
    N.J.
  3. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    776
    Omaha, NE area, US
    Steve
    While this was very common "back in the day", and is probably a benign practice, doing this always seemed to me like putting on yesterday's underwear, i.e. I'm not doing it unless I have no choice :)
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Uh Oh...sounds like I should be changing underwear more often...o_O
    308 milano, ChevyDave and bitsobrits like this.
  5. Rifledriver
    37,288
    The best advice the internet has to offer and worth every penny you paid yet not one single word on the most important issue.
    Your 76 has smaller lower drive bearings than 90% of the V8 Ferraris that followed it and need to be scrutinized very carefully once the belts are off. They can be changed using some special purpose tools with the engine installed. If it was my car and I was not well versed in their history they would be part of the job .
    moysiuan, mike996, Zenobie and 2 others like this.
  6. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,347
    Sergio Tavares
    How often do people change the tensioner spring ?
  7. Glassman
    Glassman F1 World Champ
    I changed mine with a belt swap last year. That would be the first time in 41 years.
    moysiuan likes this.
  8. Rifledriver
    37,288
    Not once in 47 years on hundreds of cars.
    Why on earth would I?
  9. lopena
    766
    Every 30 years, like clockwork.
    Alan
    N.J.
  10. windsock
    windsock Formula 3
    1,163
    One thing to inspect very carefully especially since I saw several pictures in this thread is the plastic timing gears. Many of these cars originally came with plastic timing gears on the cams. Metal hub with plastic gears. We have seen several of these fail the last few years. At this age they should be replaced with aluminum.
    Sergio Tavares and 26street like this.
  11. 26street
    26street Formula Junior
    Jan 30, 2021
    472
    Westchester New York
    Mark k
    i checked them no signs of wear or cracks and the previous owner had them done 15 years ago, i am planning on some engine work in the future and looking to upgrade a lot of things, but for now just straight maintenance, with all i have going on it is hard to find time to take the good girl out for a ride
  12. moysiuan
    moysiuan F1 Rookie
    4,255
    Canada
    #37 moysiuan, Jun 20, 2025
    I did my 35 year change interval of the springs. Due to stress relaxation, a spring does lose its strength after set in constant compression. My old springs were about 1/2 inch shorter than the new ones. As they are there to set the belt tension, new springs are useful for us enthusiast owners who are not as confident as the pros who set the tension by hand feel anyways.
    ChevyDave likes this.
  13. robertcope
    robertcope Formula Junior
    275
    Houston, TX
    Robert B. Cope
    I kinda get what you're saying, the really there's lots of oil left over in the motor during any oil change, a tiny bit more isn't going to change anything.
  14. Dockboy
    Dockboy Formula Junior
    630
    Maryland
    Keep re-tensioning your cam belts and your dreams may come true!;)
    308 milano likes this.
  15. robertcope
    275
    Houston, TX
    Robert B. Cope
    How necessary is this, really? I did my timing belt, but that was thousands of miles ago, but hadn't heard to re-tension them.
  16. Dockboy
    630
    Maryland
    Reread this thread;)
    DO NOT RE-TENSION THE CAM BELTS !
    mike996 and robertcope like this.
  17. bitsobrits
    Nov 12, 2011
    776
    Omaha, NE area, US
    Steve
    It's not the oil trapped in the filter that bothers me, it's the contaminates the filter picked up. As I posted earlier, not changing the filter every time is probably benign. but I still change it every time, because I just have to.
  18. Glassman
    I'm wondering if anyone who does a belt change every 3 years no matter the miles, and religiously includes the tensioner bearings............does an oil change without the filter!!!! I just have to know.
  19. Rifledriver
    37,288
    And how certain are you that the 2025 spring made by who knows who is exactly the same spec as the springs made in a different country by a different contractor 50 years ago?
    False sense of security.
    Nuvolari, bitsobrits and 308 milano like this.
  20. Sigmacars
    Sigmacars Formula 3
    1,241
    Go into the search section you will find 100 answers please no more Belt questions
    26street likes this.
  21. Glassman
    It's apparent that you should avoid these kinds of threads!!
    Rifledriver and Sergio Tavares like this.
  22. Sergio Tavares
    Nov 15, 2018
    1,347
    Sergio Tavares
    Are you really saying the cogs are made of plastic?
    on the Ferrari?
  23. windsock
    windsock Formula 3
    1,163
    Yep, I don't know the actual production dates that used the plastic pulleys but later 308 and early 328 have plastic pulleys molded onto a metal hub. We see them starting to show cracking from the hub outwards. The pulley in that picture is plastic.
  24. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    468
    Pacific Northwest, USA
    Dave W
    So what I'm inferring from this is that early 308s and later 328s used metal (steel?) pulleys....which means the pulleys went from Metal to Plastic and back to Metal? Sounds like maybe Enzo had a little Musk streak in him - or vice-versa - using customers as beta testers for the plastic pulleys. ¯\_ (ツ)_/¯
    - Dave
  25. Rifledriver
    37,288
    Same reason they used belts.....its cheap.
    mike996 likes this.
