CAM BELT CHANGE | Page 3 | FerrariChat
CAM BELT CHANGE
Discussion in '308/328' started by steve meltzer, Jun 18, 2025.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,295
    CT
    John Kreskovsky
    I recently started taking metformin and after 4 months I can tighten my belt 2 more notches with the same tension. :D
    Those don't resemble the pulleys on my '85 QV. February 1985 build.
    308 milano likes this.
  2. moysiuan
    moysiuan F1 Rookie
    4,320
    Canada
    Fair point. I would have been more concerned if the new one was shorter. The old one being a bit shorter makes sense from what I know/learned about springs, there is a loss of spring formula that relates to stress relaxation depending on the material type, temp etc. so I was not surprised. I suppose I could have a slightly higher tension on the belt with the taller spring. I would expect that is why you just go by hand feel, and having done one belt change I would probably be fine to tension to a hand feel next time round as well.
  3. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    ok
  4. Rifledriver
    37,353
    Point being if you rely on the spring, new or old to get tension correct you do not know enough to be doing the job.
    flyngti likes this.
  5. Rifledriver
    37,353
    I honestly do not recall with any degree of certainty but I believe they were mostly 2 valve injected era.
  6. miked
    miked Formula Junior
    Feb 7, 2001
    922
    Cincinnati, Ohio
    I believe that "early" 308's had plastic pulleys, "later" cars used metal pulleys. My car is a OCT "77 build, it has plastic pulleys. As Windsock said, plastic cog with a metal center. The guide ring is also plastic, seemingly pressed on but I have found one ring with glue residue on it, factory or repair I don't know. No cracks on any of my pulleys, I checked them over carefully.
    26street and ChevyDave like this.
  7. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    530
    Pacific Northwest, USA
    Dave W
    That could be said about virtually any replacement part for these cars.
    - Dave
    moysiuan likes this.
  8. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    The belt change interval subject on all Ferrari's with cambelts has been done to death so much on Ferrarichat, that there should be an automatic re-direct to a site statement that simply says:
    "Change your cambelts when you feel most comfortable, and change your tensioner bearings too if you think they're needed"
    With cars such as the 348/F355/Mondial T/Testarossa series and other models where the cambelt change is very labour intensive, and expensive for those who do not work on their own cars, I can understand the thinking for extending the cambelt replacement service for as long as possible (especially looking at some of the prices Ferrari specialists seem to charge in the USA - UK specialists seem to charge a lot less!)
    With the 308/328/3.0/3.2Mondial cars, the cambelt replacement is a straight forward job, carried out with the engine in situ, through the rear wheel arch, and the parts are cheap. It's not even labour intensive (compare the work required to change the belts in a Ferrari 308/328 to a 1980's BMW, a VW or a Lancia Integrale! :eek:)
    I change my belts and tensioners every 3 years (and I change my oil every year - With a new filter! ;), along with the air filter, fuel filter and coolant), because it's cheap as chips and gives me peace of mind (yes the tensioners probably don't need doing so often, but they don't add a massive amount to the bill)
    My thinking?: The cost of replacing the belts and tensioners is a damn sight cheaper than the cost of an engine rebuild due to a cambelt or tensioner failure!
    Each to their own - As I say though, the cost of a cambelt service on a 308/328 engine is hardly a bank breaker :)
    robertcope, 26street and ChevyDave like this.
  9. Rifledriver
    37,353
    #59 Rifledriver, Jun 22, 2025
    No, not true at all. A gasket fits or not, bearing size and quality is easily determined. Most parts suitability is generally very easily determined by a knowledgeable mechanic by at the most, basic tools at hand.
    How many of you spent more than 8 seconds determining the suitability of the spring?
    And it does not begin to address my point. If the spring is all that you have to establish correct belt tension put the tools away and get it done by someone who has a clue.
    Sergio Tavares likes this.
  10. miked
    Feb 7, 2001
    922
    Cincinnati, Ohio
    Another thing to consider is that timing belts in automotive engines was relatively new technology at the time with the Boxer being the first production Ferrari utilizing them only a couple of years prior to the 308. Not yet proven in long term use and failures in any brand car would lead Ferrari (and other manufactures) to adopt a short replacement life recommendation out of an abundance of caution. Witness Ferrari's slow adaptation of disc brakes, they let others do the development and jumped in only after they were proven to be reliable long term.
    I would agree with 4rePhill, change the belts when you feel the need.
    Those of thus around at the time when timing belts were starting to appear on engines can remember that they were truly advanced technology. My cousin bought a Pontiac with their OHC 6 cylinder engine when it came out in 1966. He opened his hood constantly for people (gearheads in particular) to gaze in wonder at the strange arrangement at the front of the engine. The Fiat 124 followed shortly after, another engine with a prominent timing belt arrangement at the front. As a side note my son recently acquired a Fiat 124 spider from an estate in his wife's family. It had been sitting for 30 years and after prudent replacement of some components (timing belt included) and a carb rebuild the engine fired up at the first turn of the key. The engine was designed by ex-Ferrari engineer Lampredi, a wonderful little unit. Parts for the Fiat 124 are, in direct contrast to Ferrari, amazingly cheap rivaling the VW aircooled Bug in low cost.
  11. 308 milano
    308 milano F1 Veteran
    5,351
    Montana
    Kim
    RITIS -
    Run It Til It Snaps!
  12. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,286
    Illinois
    I would add to stay away from SKF bearings (double race). Had them installed by a Ferrari dealer because that's what Ferrari recommended and when I went to do my own belts, the grease had flown out of the bearings and made a nice line around the inside of the covers. In addition, the bearings were noisy when I changed them. I use only Hill Engineering bearings now and have not had that experience since then.
    26street and Sergio Tavares like this.
  13. Rifledriver
    37,353
    Fiat used them far before Ferrari. Fiat owners in the USA did not take preventative changes seriously and they became famous for belt failures. It killed the Fiat market in the USA and they have never returned.
  14. JCR
    JCR F1 World Champ
    11,103
    H-Town, Tejas
    (PDF) DEVELOPMENT OF TIMING BELT DRIVES
    HISTORICAL DEVELOPMENT OF TIMING BELTS
    Timing belt is a relatively young drive, firstly designed as a drive for a sewing machine by
    engineer Richard Y. Case in 1946. It was a rubber belt with trapezoidal teeth profile. After
    twenty years, in 1962, the timing belt was for the first time built in an automobile, Glas
    1004. Engine of Glas 1004 was the first engine where the timing belt was utilized as the
    camshaft drive (Synchroflex). Valve train was very simple and the timing belt drive had no
    belt tensioner, Figure 1. Massive use of the timing belts started at the end of 1960’s on Fiat
    125 and Fiat 128 automobile and, at the beginning of 1970’s, on the first Golf automobile.
    After initial doubt, almost all producers of Otto and Diesel engines for passenger cars have
    utilized the timing belts. The timing belt is today the most frequently used camshaft drive.
    Application of the timing belts is mostly linked to automobiles, though just 2% of timing
    belt production is intended for application in automotive industry.
    Glas (company) - Wikipedia
  15. Rifledriver
    37,353
    Not very up to date information.
  16. BigTex
    79,418
    Houston, Texas
    Bubba
    Portofino and robertcope like this.
  17. robertcope
    robertcope Formula Junior
    276
    Houston, TX
    Robert B. Cope
    I would be tempted to replace those fuel lines while I'm there, too.
    ChevyDave likes this.
  18. moysiuan
    moysiuan F1 Rookie
    4,320
    Canada
  19. BigTex
    79,418
    Houston, Texas
    Bubba
    Of course, the original problem was: Won' t run bad gas.
    But as the Service Department knew me and the car, they started with First Things first.
    So with the belt change, comes:
    Degree the cams
    Check the cam drive bearings
    Inspect the cogged drive wheels fior cracking and fence damage.
    Check the shims at the cam lobes.
    ..and on and on and on.
    As they "back out of there, they have to clean the carbs (rebuilt less than 5K miles ago), I had installed fresh plugs and fuel pump.
    Fuel filter
    All fuel lines to modern spec.
    They certainly can replace all that braided hose you see there, but those are not fuel lines....:D
    WUR I think......
    I did agree they can finish the cam covers with flat aluminum as on our North Amercain cars they do not match anyway.
    So they will make them match!!
    Adding a shut off valve at the LH fuel tank would be a nice mod, so you could change the filter without drsining the tank
  20. BigTex
    79,418
    Houston, Texas
    Bubba
    It's funny, I have a Ziplock from the 'first problem" when I bought the car:
    Exploded front header failure from intermittant operation of MSD aftermarket ignition.
    That was a tough self repair as the header is in place when Ferrari drops it in.
    And the flames blowing out of the collector against the RH fuel tank COULD have been exciting too!
    QUIZ:
    What important part do you see here, that needs to go back in????
    :D :D :D
  21. BigTex
    79,418
    Houston, Texas
    Bubba
    Answer:
    NOT the asbestos from the header wrap.
    NOT some of that braided hose like you observed.
    The sheet metal screw/washer is at the top[ of the inner fender into the frame of the engine compartment.
    The most importsant bit is that Intake Trumpet Base gasket bushing.
    I knew I was missing one as there's 16 and they are easily dropped when pulliing the airbox and trumpets off.
    I knew I only had fifteen, and the Tech on my engine does too!
    They go on the carn studs as kind of a "crush limit" to the base gasket, I think.
    There was a tiny metric machine screw/washer in there too, that holds the forward lower inner fender in at the front edge.
    Ferrari just had odd ways of building things, pop rivets being the favorite body fastener of all!
  22. 308 milano
    5,351
    Montana
    Kim
    I just swap each belt to opposite banks..
    Tension that had been pulled in one direction for last 4 years is then pulled in opposite direction returning the belts to new condition.
    LostAussie likes this.
  23. Glassman
    Glassman F1 World Champ
    This is brilliant and thanks for the money saving tip. With now knowing I can go for several belt changes with the same belts and oil filter......... owning a Ferrari is actually saving me money. Now if I can just figure out how to use Penny's for valve shims the savings will be rolling in!!!!
  24. robertcope
    276
    Houston, TX
    Robert B. Cope
    So these line are not fuel lines?
  25. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    246
    Boerne, TX
    Rodney Bolt
    I'd have a serious case of the ass if I saw my mechanic put all that crap on the roof of my car, dirty oily parts in the trunk and zero blankets to protect the paint. Does he have any respect for your property?
    robertcope likes this.
