News
Cam Cover Patina
Discussion in '308/328' started by Lowell, Feb 20, 2019.
  1. Lowell
    Lowell Formula Junior
    Silver Subscribed Owner
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
    Recently I cleaned the cam covers on my 1984 308 QV. Perhaps I did this too vigorously. At any rate, the result was a blotchy finish. This blotchy finish could, of course, always have been there and just hidden by the oily dirt.
    So I am looking for some way to bring back the original surface finish on the cam covers. I do not want a shiny finish, just the original, rather subtle, finish. Any suggestions would certainly be appreciated.
  2. Rifledriver
    Rifledriver Two Time F1 World Champ
    26,404
    Austin TX
    A picture would help some. I suspect what you are experiencing is what I have seen many times and is a real problem if you are really trying for a new and original look. The covers are an alloy that discolors and can be a real problem if you really want to preserve the original looking finish. Bead blasting makes it uniform but in an unmistakably bead blasted looking finish which I really do not care for. You could find someone who does walnut shell blasting though from direct experience I suspect it will make it better but not what you really want. I have wanted to try soda blasting but have not yet done that so I cannot tell you the outcome of doing that. I suspect like most aluminum it will make it brighter but may or may not change the blotchyness.
  3. Lowell
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
  4. Lowell
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
  5. Rifledriver
    26,404
    Austin TX
    Pretty typical and a real issue if restoration of the original look is desired. To be honest I don't think you'll be able to make them look like new. I have considered experimenting with various powder coat colors to try and do that. If you can't live with it try soda blasting and see what happens. They can be better with walnut shell blasting but it will not be a huge improvement.
  6. absostone
    absostone F1 Rookie
    4,531
    Fchat
    cmt6891 and 19633500GT like this.
  7. absostone
    absostone F1 Rookie
    4,531
    Fchat
    Oh then lightly sand with grey scotchbrite pad to smooth finish. Real easy to do
  8. Michael Call
    Michael Call Formula Junior
    Mar 6, 2008
    829
    S.L.C. Utah
    Michael D. Call
    Two words. VAPOR BLASTING. This will achieve the finish you want.
  9. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    Ya know, I have been looking at Vapor / Liquid blasting recently for just that reason. It seems to make the pot metal and aluminum parts like they should, smooth and a little shiny. I am more prone to purchase a small unit than to send stuff off. the small units are REALLY small, benchtop size. The larger units are REALLY expensive and take up a lot of space. Maybe I could get rid of my dry blaster...
  10. Michael Call
    Mar 6, 2008
    829
    S.L.C. Utah
    Michael D. Call
  11. John F
    John F Rookie
    Jun 24, 2010
    40
    East Lothian, UK
    John Ferguson
    Before and after vapour blasting. The natural patina will return over time.
  12. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    Anyone doing vapor blasting at home?
  13. Michael Call
    Mar 6, 2008
    829
    S.L.C. Utah
    Michael D. Call
    Here is a photo of the finished engine compartment with the vapor blasted cam covers. I think it looks the business..
  14. johnk...
    johnk... F1 Veteran
    Jun 11, 2004
    7,648
    New England/FL
    Those don't look right, but I don't recall the cam covers on my 85, bought new, ever having a uniform color to them. They were never polished. Pretty much looked like they were pulled from the die cast mold, machined as necessary and installed. Never looked like those vapor blasted in posts 10 & 11.
  15. Michael Call
    Mar 6, 2008
    829
    S.L.C. Utah
    Michael D. Call
    Oengus, Saabguy and 53ford like this.
  16. johnk...
    johnk... F1 Veteran
    Jun 11, 2004
    7,648
    New England/FL
    No, my 85 didn't look anything like that from the factory. I remember because I thought about pulling the covers off and cleaning them up right after I got the car, but never did.
    Martin308GTB and Rifledriver like this.
  17. offtheworkigo
    offtheworkigo Karting
    222
    Dallas
    Dave Hoffer
    Water blasting is the only way to go. Tim Taylor did my painting and water blasting on the aluminium valve covers and intake. Image Unavailable, Please Login Call him for a price very nice guy. 214-317-2762
    Oengus, moysiuan and Michael Call like this.
  18. Rifledriver
    26,404
    Austin TX
    Not what I would call a correct finish.
  19. Rifledriver
    26,404
    Austin TX
    Agree 100%
  20. Rifledriver
    26,404
    Austin TX
    Not a single one of those looks original.
    Martin308GTB likes this.
  21. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    410
    Elgin, IL
    Dave
    As long as you are not painting them red...
    Martin308GTB and absostone like this.
  22. Martin308GTB
    Martin308GTB F1 Rookie
    3,886
    SW-Germany
    Martin N.
    'Better' looking than what came from the factory. Is this really desired that much?
    Each time I have my covers off I clean them with a chemical aluminium cleaner stuff, which just cleans and brightens the metal, and think, that's what I remember seeing Ferrari V8s back in the 70s at car shows. Good enough for me.
    Best from Germany
    Martin
    Rosey likes this.
  23. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,140
  24. cloverleaf
    cloverleaf Karting
    Jun 16, 2013
    85
  25. Martin308GTB
    3,886
    SW-Germany
    Martin N.
    JuLiTrO and Saabguy like this.
