News
Cam Cover Patina
Discussion in '308/328' started by Lowell, Feb 20, 2019.
  1. Crowndog
    Crowndog F1 Veteran
    6,861
    Fairfield,Pa
    Robert
    Pictures?
  2. Martin308GTB
    Martin308GTB F1 Rookie
    3,891
    SW-Germany
    Martin N.
    Sorry Robert, but no. But you could 'silver subscribe', go to the FChat 'Backroom Lounge - Bikini Thread' and compare it with the european Playboy-issues. :)
    Best
    Martin
    Crowndog likes this.
  3. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    MARTIN! You left out the important phrase, "Or so I've heard." ;-)
    Lester
  4. Martin308GTB
    3,891
    SW-Germany
    Martin N.
    Why Lester?
    That recommendation to Robert is, what I permanently do myself :)
    Best from Germany
    Martin
  5. Crowndog
    Crowndog F1 Veteran
    6,861
    Fairfield,Pa
    Robert
    That’s usually my disclaimer.
    Rob
    Saabguy and Martin308GTB like this.
  6. 4redude
    4redude Formula Junior
    Jan 13, 2005
    671
    Someplace new
    Brian Keegan
    The most correct finish I have seen is a vibratory tumbler.
  7. moysiuan
    moysiuan Formula 3
    1,659
    Toronto, Canada
    Andy
    Som of these peices look really nice with all the specialized preparation. To stay closer to the OEM finish, which as noted was not so perfect at all, just try some hand polishing with a a compound like eg. Menzerna universal polishing cream. Will reduce the blotching without changing the surface finish. May as well give it a go, and if it doesn't clean up to your satisfaction then try the more aggressive approaches.
  8. kcabpilot
    kcabpilot Formula Junior
    Apr 17, 2014
    842
    California SF area
    Paul
    #33 kcabpilot, Feb 24, 2019
    I've considered vapor blasting which seems to completely remove the "patina" It looks very nice but I'm not sure how long it will last in a working engine compartment. The shape and position of the cam covers makes it impossible to periodically just wipe them clean. So I cleaned mine in the blast cabinet then spent hours with Scotchbrite pads and microfiber towels buffing down the rough texture produced by the blast media. Not a method I would recommend due to it being rather labor intense. But I'm pretty happy with the appearance it is after all, an engine and not a dining table. I did polish the Ferrrari logo and raised strips with a piece of 7000 grit sandpaper just to give them some highlighting.
    Rosey and moysiuan like this.
  9. Rosey
    Rosey Formula 3
    Nov 5, 2015
    1,655
    Australia
    Mark R
    Lowell I just checked my car which has the original cam covers unfinished and browsed through many of my period Ferrari books and the original covers do have a slightly mottled appearance. Maybe a little less than yours but they are certainly not uniform in colour like many of the examples above.
    Rifledriver likes this.
  10. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    So does anyone have any parts that have been vapor blasted and used in an engine bay for any time? I am curious to see what happens with high temperatures and oil, dirt, etc. I understand that I may lose concours points but at present, mine are in "failing red" where there is red paint flaking off the cam covers and that needs to go. I mean it is going slowly but I might like it to go faster.
  11. Rifledriver
    Rifledriver Two Time F1 World Champ
    26,423
    Austin TX
    What do they look like under the paint? Its not like we require brand new looking covers. But a patina or even some stains are preferable to an incorrect finish. We are trying to reward originality, not the shiniest parts.
    I'd walnut shell blast them and see what you have.
    Rosey likes this.
  12. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    Looks like hell. Places with paint remaining are lighter (?) than those where paint flaked off some time back. I am not willing to take off the cam covers just to pretty it up but when that time comes I would like to get it right.
  13. Mike C
    Mike C F1 Veteran
    Owner Lifetime Rossa
    Aug 3, 2002
    6,069
    Southeast USA
    Mike Charness
    While still on the car, cleaning with a toothbrush and a paste made from Bon Ami works well.
  14. Lowell
    Lowell Formula Junior
    Silver Subscribed Owner
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
    Still looking for a way to fix blotchy 308 cam covers.
    Does anyone know about airplane aluminum skin coating --- a clear coating that inhibits corrosion? Image Unavailable, Please Login
    I'll try to attach a photo I found on the web of some airplane coating that may look like the original cam cover finish.
  15. kcabpilot
    Apr 17, 2014
    842
    California SF area
    Paul
    Don't use any sort of clear coating. I once used a product called Nylac from Eastwood on my Alfa cam cover. It was advertised as being specifically for such purpose. Looked good for about a year then began breaking down and looked like hell. Also took a hell of a lot of work to get it all off. Any kind of coating on an engine part will, just like paint, eventually go south and look like a mess. For aluminum I've found that naked is the best way to go long term.
    Rifledriver and Rosey like this.
  16. Lowell
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
  17. Hannibal308
    Hannibal308 F1 Rookie
    3,560
    HDH - SBA - P52 - JWY
    Will
    Try it on something else first. Like your shifter box or the foot pedal box. Both hidden but raw aluminum
  18. Lowell
    Apr 17, 2005
    887
    Santa Fe, NM
    Lowell Brown
    Image Unavailable, Please Login I made the cam covers look somewhat like airplane wings. Here is a photo showing the cam covers attached to the engine.
    Any comments?
    Crowndog and miketuason like this.
  19. Saabguy
    Saabguy Formula 3
    1,444
    Shreveport, LA
    So Lowell, what did you end up going with? Looks nice from what I can see.
