348 - Cam Phase Senor replacement | FerrariChat
348 Cam Phase Senor replacement
Discussion in '348/355' started by joshtownsend, Feb 21, 2024.
  1. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    421
    H-town...TEXAS
    #1 joshtownsend, Feb 21, 2024
    Hello all,
    Recent did another engine out and was coming back with a code. When looking at it, it pointed to the phase senor on to 1-4 side. When i pulled it out, the connector fall apart in my hand. This is apparently normal so i'm looking for replacement.
    The original part number is # 146312.It is discontinued and spare parts have dried up for the most part.That being said, i don't believe that Ferrari made this part. I'm sure that the sensor itself is not made by Ferrari.
    I have found a Bosch 9146108. The connector will fit but not sure about the sensor itself.
    https://www.fcpeuro.com/products/volvo-camshaft-position-sensor-rear-of-exhaust-camshaft-0232101030?ads_cmpid=14308704881&ads_adid=126404518775&ads_matchtype=&ads_network=g&ads_creative=539621335898&utm_term=&ads_targetid=pla-293946777986&utm_campaign=&utm_source=adwords&utm_medium=ppc&ttv=2&gad_source=1&gclid=CjwKCAiA29auBhBxEiwAnKcSqgxn2WgNIIJMxmTCevDjTJmwUd-Ew5mD6VZEBJUnKCD_Y7HtXOLLcRoC8skQAvD_BwE
    Does anybody have any experiences with swapping this sensor out?
  2. Qavion
    Qavion F1 World Champ
    14,272
    Ian Riddell
  3. joshtownsend
    Jul 12, 2007
    421
    H-town...TEXAS
    Ahh.. Which way does the pins go?? Since is fell apart in my hand, not sure , any diagram?
  4. Qavion
    14,272
    Ian Riddell
    #5 Qavion, Feb 21, 2024
    The 348 wiring guru, @m.stojanovic may be a little busy at the moment, but this is what I have for the 348 2.7 car.
    Can you see the colours of the wires on the car side of the plug? Or is the harness sealed?
    pin 1 pink/black goes to red wire
    pin 2 pink wire goes to green wire
    pin 3 black wire goes to black wire.
    Probaby best to confirm with a multimeter:
    You should be able to see 12 volts on the pink wire (with a voltmeter with the ignition turned on) and an earth (with an ohmmeter) on the black wire.
  5. joshtownsend
    Jul 12, 2007
    421
    H-town...TEXAS
    That's exactly what i need. The connect from Hall is a female, so i ordered on offline. Its a bosch EV1 3 pole connector.
    Thanks!!
    Qavion likes this.
  6. m.stojanovic
    m.stojanovic F1 Rookie
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Qavion likes this.
  7. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    As a temporary repair of my desintegrated Cam Sensor connector, I cut-off the connector from a used crank sensor and soldered it on. It worked very well and could have been a permanent solution but I later moved it to spares and installed a new one.
    Qavion likes this.
