Cam pulley spot welds | FerrariChat
Discussion in '348/355' started by Jamie H, Jan 10, 2010.
  1. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    Good evening everyone,
    I am in the process of a major service on my Mondial t and had read somewhere about spot welding the 'guides' on the cam pulleys. I have tried looking for a thread as I am sure that someone has already written about this issue. I checked mine and the only one that is loose at the moment is the intake pulley on bank 1-4. I do intend in spot welding all of them but was looking for a recomendation as to how many welds etc. Could anyone please guide me to the thread that talks about this?
  2. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Jamie - I think Daniel with Ricambi had pulley "fence" failures and posted several times about spot welding his fences with (I believe) 3 TIG spot welds on each fence (120deg apart). I'm sure Daniel would be happy to discuss with you. I think a key precaution is to make sure that timing belt(s) don't ride on these fences after you have installed them. IE, turn the engine over by hand for a time and see where the belts ride. If they ride on the fences, I'd check for reasons why... ie, tensioner bearing play, or other alignment problems. Hope this helps (I also couldn't find a thread).
  3. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    just spot weld it. i did all of mine for the "just in case" and did 4-5 welds. doesn't have to be tig, i migged mine and just ground down any excess. do it on the side the belt does not run on. simple easy --hard to screw up.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    This isn't just an issue with the cam gears, of course. There's also a fence on the lower gear that can come loose and destroy the belt.
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    I am going to weld all mine up (if they havent already been done) when I pull the engine out to do my major service. :):)
  6. jqpd99
    jqpd99 Formula 3
    2,486
    Ottawa
    DFO
    Here's how I did mine...
    http://ferrarichat.com/forum/showpost.php?p=137615396&postcount=145
    DF
  7. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    Thanks everyone. I will mig them in place after I get the pulley's off, with pictures of course.
