Cam pulleys? | FerrariChat
Cam pulleys?
Discussion in '308/328' started by mike996, Apr 1, 2021.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,878
    Mike 996
    I had not noticed this in previous belt change - or maybe I forgot I noticed it. :confused:
    The two intake cam pulleys - one on the front back, one on the rear bank - have what look like retainers on one side of the pulley. On the rear bank (1-4), the retainer is on the outside of the pulley, on the front bank (5-8) it is on the inside - pics attached. Is this normal/correct? Seems odd to me. I would think both would have the retainer on the same side.
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Normal and correct.
    waymar likes this.
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,878
    Mike 996
    Thanks Brian! :)
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    Those are called "fences" and they are meant to locate the timing belt position on the pulleys. So one fence guides the belt to the front and one fence guides the belt to the rear and the result is the fence stays put.
    I am doing timing belts on my Ducati 907 and they have fences on the same side of the both pulleys. It made stretching the belt over the pulley way too hard. One of the posters on Ducati Chat suggested "cutting the fence off with a side cutter" to which I responded effing bogus. I hate it when people suggest bad ideas they never tried.
  5. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,878
    Mike 996
    "I hate it when people suggest bad ideas they never tried."
    Ah, but it wouldn't be the internet we all know and love if only correct, factual information was presented! Heck, think of oil threads; if real, scientific test data was required, there wouldn't BE any oil threads! :p
    Saabguy and Brian Harper like this.
  6. yelcab
    Nov 29, 2001
    13,605
    San Carlos, CA
    Mitchell Le
    I am not requiring scientific data, just that you have tried it and see how bad of an idea that was "cutting the side fence off with a side cutter." It would leave sharp edges to cut your hand and the belts. And you cannot cut through 20 gauge steel with a side cutter.
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,878
    Mike 996
    I totally agree, it's an inane suggestion. :eek: Very hard to believe anyone over age 7 would make it!
  8. JC1720
    JC1720 Karting
    Jan 21, 2016
    139
    Did they suggest cutting them off while the engine’s running? I’ll bet someone tried... :):)
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Just to let you know, not all car manufacturers uses fence on their cam pulley. For example the later 79 -82 twin cam Lancia Beta engine doesn’t have the fence on both the intake and exhaust cam pullies but it does have one on the bottom auxiliary pulley.
  10. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    hi mike
    can i ask when those belts were changed last and how many miles you've put on them, as not sure if camera/light angle but the edges of the belts look worn.
    just to get an idea.
    cheers
  11. Milkshaker0007
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    sorry
    just noticed your other thread :)
    "Removed the old belts. They were 6 years old but only a bit over 6k miles on the car in that time."
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,878
    Mike 996
    Paul, YEP...6 years. Check the other thread again, I just added some new FWIW info/pics.
    Milkshaker0007 likes this.
