Cam seal leak ?? | FerrariChat
Cam seal leak ??
Discussion in 'Technical Q&A' started by todd6363, Feb 18, 2007.
  1. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
  2. tbakowsky
    Sep 18, 2002
    20,021
    The Cold North
    Tom
    wash it down..go for a drive and recheck. More then likely just a cam cover leak, or the o-ring seal around the cam seal housing is pinched. Either one requires cam cover removal to fix. good luck!
  3. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    As Howie just mentioned. Clean the area down with a good degreaser, then hose off and road test or keep an eye on it for a couple of days and see where the leak is coming from. :):)
  4. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    What happens in this area is most people put a little gasket sealer (silicone type) on these gaskets right there where the gasket meets the O-ring. The gasket either slips out as the cover is tightened or shortly there after.
    To prevent this, a pro told me that he uses a little Three Bond silicone sealer in this area, then lightly tightens the cam cover nuts and ensures that the gasket ends don't slip out. To ensure that the gaskets don't slip-out, he lets the car sit at least overnight before completing the tightening.
    It wouldn't be too much of a job to reseal the cam covers.
  5. todd6363
    Jan 20, 2007
    270
    Ohio
    Todd
    #5 todd6363, Feb 19, 2007
    Going to degrease and wash everything off today. Will have to do with just bringing the car up to temp. in garage and rechecking. I have 14 inches of snow up here and its 9 degrees outside. Hopefully its just the cam cover leaking. Will be replacing the cam belts, water pump, etc. next week so I'll be sure to get more pics where the cam cover and O-ring meet. Thanks again everyone. Pic is new 83qv that I got home Sat.
  6. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Gorgeous looking car mate. :):)
  7. todd6363
    Jan 20, 2007
    270
    Ohio
    Todd
    Thanks Pap
