Cam Seal leaking | FerrariChat
Cam Seal leaking
Discussion in 'Technical Q&A' started by jonathan.mccall, Feb 11, 2009.
  1. jonathan.mccall
    jonathan.mccall Karting
    Jan 25, 2008
    131
    N.Ireland
    Johnny Mccall
    Ive a camshaft seal leaking!
    My 3.2 Mondial doesn't need a belt service for at least another year. I doubt there is no other way to fix it, and while replacing the seals it would be stupid not to replace the belts etc...
    Exactly what all do i need apart from the service kit. Mondial 3.2 Kit includes : Air Filter, Oil Filter, Fuel Filter, Cam Belts,Timing Belt Tensioner Bearings, Alternator Belt and Air Con Belt.
    ie 0 ring seal kit and gaskets???
  2. Ricambi America
    Sponsor Owner
    #2 Ricambi America, Feb 11, 2009
    The 3.2 kit (at least ours does!) should include 4 x cam seals, 4 x cam-orings, and 2x distributor oil seals... in addition to a bunch of end plate gaskets, valve cover gaskets,etc.
    http://www.ricambiamerica.com/product_info.php?cPath=40&products_id=171
  3. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    also,when you do the change at the cam seals a little dap of silcone at the corner will asure no leakage in the future
  4. jonathan.mccall
    Jan 25, 2008
    131
    N.Ireland
    Johnny Mccall
    That's great Guys thanks for your help and advice!
    Could you be more specific about the silicone on the corner please mike!
    Just so i can tip off my mechanic. He used to service Eddie Irvines Ferrari's back here in Ireland...
  5. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    the machanic that worked on my engine put just a dap of silcone at the corners,of the cam seal seems that when the covers go back on the gaskets don't make a tight seal,anyway weather its right or wrong I don't have any leaks,I have over 54k miles,just 1k miles since the major
  6. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    #6 RGigante, Feb 12, 2009
    Here's a picture of my 328. You can see the use of (red) silicone on the corners only (on the right side of the picture)
    I did use a little bit on the left side, too, at the place were the gaskets meet at 90º
    5.000Km later, no leaks
  7. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    thats what my mechanic did too! more so on the rear bank,no leaks or drips,I'm happy :)
  8. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    As long as its not leaking on the timing belts, I would let it be until the next major service is due...7-10 years or 30k miles.
  9. jonathan.mccall
    Jan 25, 2008
    131
    N.Ireland
    Johnny Mccall
    Thanks for the pic! I'm going to show it to my mechanic! It should be a great help in stopping it from leaking again...
  10. jonathan.mccall
    Jan 25, 2008
    131
    N.Ireland
    Johnny Mccall
    Hey Frank! Its not leaking over the belts!
    Since i noticed the leak i took the exhaust guard off and painted the garage floor, its made it v hard to live with!!!
    I spoke to the garage 15 months after the service, and they said they would have stood over it for the 1st 12 months boo hoo!!!
    He said he had the same problem with a TR and replaced it FOC as it was within the 12 months boo hooooo!!! (Faulty seals he said)
    Ah well the garage is in England where i bought the car and I'm in Ireland...
    PS maybe i should put a sponge on top of the exhaust guard until the next service ha ha
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Can dripping oil get sucked into your alternator & ruin the brushes & slip rings?
    It can if you've got the alternator with just a flat disc shaped plate on the back(been there). If your alternator has the casting with a orange flex air intake tube you should be OK.
  12. jonathan.mccall
    Jan 25, 2008
    131
    N.Ireland
    Johnny Mccall
    Good point I will have to check that out thanks!
    I went from leaving it til the next belt service (Year and a half ) to doing it in 2 weeks time, all in one day!
    Think its best to do it now!!!
