Cam Seals '87 328 gts | FerrariChat
Discussion in 'Technical Q&A' started by 1987ferrari328gts, Mar 17, 2016.
  1. 1987ferrari328gts
    Mar 17, 2016
    2
    Penticton BC Canada
    Roderick Strike
    So looks like I have a leak from one of my cam seals. Passenger side. It is minor but I am going to have it replaced. I am at just under 28k miles and last year performed a major maintenance, ALL belts, water pump, all hoses, all fluids flush and replacement, the list is endless. Can anyone give me an idea what labor time is involved? And also perhaps what else is expected to be done at the same time. Cheers
  2. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Roderick, I had the same issue on my 328. With regard to your question "what else is to be expected to be done at the same time," you might want to check out the following thread: http://www.ferrarichat.com/forum/308-328-sponsored-yellow-compass-group/400029-328-cam-seal-housing-o-ring-leak.html. Take a look at post #25 for details, but in October 1991 Ferrari came out with a service bulletin (SB 10-31) describing a procedure to modify the cam seal housings to assist with oil drain back into the heads. During my last major service I installed updated cam seal housings along with enlarging and re positioning of the rear bank exhaust drain back hole and I have been leak free ever since.
  3. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    If your major last year was at an authorized dealer, and they did cam seals (which may be part of the "factory" major), then it may be covered by the Ferrari parts/labor warranty.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    It is like doing your timing belt again. 16 hours.
  5. mwr4440
    57,962
    Bavaria, The 'Other' Germany
    Mark W.R.
    Is this a problem with 308's as well?
  6. Rifledriver
    37,094
    Not much of one on a 2v like yours. As much as I like the 4v motor the cam seal arrangement was unbelievably stupid.
  7. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    The major service term for 3X8's is often confused with a belt service, which as you describe, sounds like what you had done. A major would include removing cams, distributors, adjusting valves, belts, tensioners..... If in fact you did get a major then go back to your tech.
    With that said is the oil leak from the cam covers or at the distributor shaft ? Two different seals.
  8. Rifledriver
    37,094
    Passenger side is a cam seal.
  9. Rifledriver
    37,094
    Dealer or not, good shops warranty their work.
  10. mwr4440
    57,962
    Mark W.R.
    As always, Thanx Brian.
  11. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    Yup, that's right! I missed that part.
  12. 1987ferrari328gts
    Mar 17, 2016
    2
    Penticton BC Canada
    Roderick Strike
    Thanks for the Excellent info. Any way I could get my hands on a play by play procedure on cam seal replacement? Cheers
  13. Rifledriver
    37,094
    Well, most people doing it don't have a good play by play or they wouldn't have so much trouble with leakage since they came into being in 1983. The parts the factory finally came up with to make it work are not even available anymore.
  14. SpyderGT
    SpyderGT Formula Junior
    May 15, 2005
    997
    Vancouver, BC
    Jon
    Roderick, I can't add anything to the technical question, just wanted to say hello to another 328 owner in BC. Any chance you'll be bringing your 328 down for the annual Father's Day Italian and French Car Show in North Vancouver? Jon
  15. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    So the driver side should be a distributor shaft? I just discovered the leaks from there.
  16. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
  17. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    One of the design flaws of this arrangement is use of a round O-ring in square channel which is liable to being pinched when the cover is put on.
    X-rings fit much better here. I used these with no leaks. Also remove any burr on the end corners of the machined channel for the ring.
    The size of the rings is 4330 (BS330 in UK).
