348 - Cam sensor seal orientation | FerrariChat
348 Cam sensor seal orientation
Discussion in '348/355' started by luckydynes, Jun 29, 2023.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #1 luckydynes, Jun 29, 2023
    Might seem like a dumb question but is this seal supposed to be backwards?
    it’s in the cam sensor housing… this side of the housing faces the motor.
    Thank you.
  2. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Looks correct as far as I can see.
  3. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    So the orientation is opposite to the cam seals? Always thinking too much so is the reason because the heads see vacuum from dry sump? Usually that surface is always “out” unless the motor is pulling internal vacuum from dry sump or vacuum pump etc.. so just to clear this pic the flat surface is in towards the motor.
    Thanks for clarification!
  4. Rifledriver
    37,087
    Backwards. The side exposing the spring is supposed to be facing the interior of the motor just like all the other seals.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,217
    Serbia - Niš
    Miroljub Stojanovic
  6. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Thank you gents!
  7. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    It is a bit odd the way it looks, make sure when you slip it on the can doesn't catch on the seal, it is very easy for that to happen.
  8. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I meant CAM not can...lol
  9. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Yea the spring wanted to keep popping out of the seal. I had the cam sensor attached and when I removed that completely I was able to manipulate it on. A trick someone shared with me was to pack the back of the seal with vasoline but it still wanted to pop out so removing the cam sensor so I was working with just the base seemed to help.
    Thanks gents.. appreciate the feedback and advice.
