Cam timing on 355 | FerrariChat
Cam timing on 355
Discussion in 'Technical Q&A' started by Barnone 308, Nov 2, 2009.
  1. Barnone 308
    Barnone 308 Formula Junior
    Mar 22, 2004
    432
    canada
    Quick question.
    When doing a belt service on a ferrari 355, when setting up the cam timing, do you just set cyclinder # 1 at top dead centre, and move the cams so they align with the marks, and then just put the belt on, tighten with the tensioner and thats it.
  2. nizam
    nizam Formula 3 Owner Silver Subscribed
    Jul 9, 2004
    1,563
    San Jose, CA
    Ni Zam
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The marks get you in the ball park--that is the engine will turn over and not bend valves.
    There are 32 teeth on the pulley to belt interface or 11 degrees 15 minutes per tooth
    There are 18 holes in the pulley to cam interface or 24 degrees/hole
    There are 14 teeth in the cam shaft face set at 22 degrees 30 minutes
    So, there is a hole on the cam for every 2 teeth on the belt,
    By playing with which tooth on the belt and which holes are sellected for the dowel, one can set timing to better than 1 degree 30 minutes.
    Rotate the engine until #1 cylinder TDC.
    Assemble the Camshafts, pulleys, and belts
    Fit tensioners
    Stretch the belts so tension wheel has 2.5mm of clearance
    Observe that intake cam is on an intake phase
    Place dial indicator on outside bowl of #1 cylinder intake
    Zero dial indicator while tappet is on base circle of intake cam
    Rotate camshaft until dial indicator reads 2.41mm
    Observe the alignment betrween the pulley holes and the cam timing holes.
    One of these holes will be best aligned with the cam holes
    Insert retaining dowel in this combination of holes
    Torque retaining nut to 8.8N.
    Observe that the exhause cam is on an exhaust phase
    Place dial indicator on exhaust valve tappet
    Zero dial indicator while tappet is on base circle of exhaust cam
    Rotate camshaft until a dial indicator reads 2.29mm
    Rotate engine 270 degrees (repeat as above)
    Rotate engine 450 degrees and recheck #1 cylinder cam indicator readings
    Rotate engine 270 degrees and recheck #8 cyclinder cam indicator readings
