Cam timing | FerrariChat
Cam timing
Discussion in 'Mondial' started by Nathan76, May 2, 2015.
  1. Nathan76
    Nathan76 Formula Junior
    Jun 20, 2013
    344
    Leicestershire, UK
    So what was a high hydrocarbon emmissions report has turned into a misfire on the rear bank.
    Compression test completed and compressions in all cylinders is good.
    Good strong spark
    So the only things left now are injectors which are a pig to get to on the rear bank or cam timing.
    Question is with the cam timing the maintenance manual shows a tool that aligns the notches in the pulleys to TDC. However on removal of the cam cover there seems to be a timing plate fitted. However the pointers on the timing plate are offset and don't match up the notches at TDC.
    So what is correct the manual or the timing plate?
  2. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    #2 MvT, May 2, 2015
    You are getting there ;)
    Regarding your cams. if you turn another 180 degrees will they line up? There should be little notches on all the cams and they all should line up at the same time. Then have a look in the inspection hole of the flywheel and there is notch (PM.1) that should be line up as well. If that is correct you should be good.
    When you change the timing. Manually do at least 2 turns to see if you do not hit any valves.
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
  4. Nathan76
    Jun 20, 2013
    344
    Leicestershire, UK
    Thanks guys
    Cam timing found to be advanced. Unburnt fuel being pushed out of the exhaust valves.
    Hopefully mot pass on monday
  5. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,678
    Argent/Brasil
    Guido
    What car is this ? Not a mondial...a 365 ?
    Guido
  6. Nathan76
    Jun 20, 2013
    344
    Leicestershire, UK
    Mondial 3.2 cab
  7. Steve Magnusson
    26,840
    What was the magnitude of the error? A couple of teeth pitch (like suggested in your photo) or a few degrees?
  8. theunissenguido
    Jan 21, 2004
    2,678
    Argent/Brasil
    Guido
    I wonder why there is no picture of your mondial.
    Guido
  9. theunissenguido
    Jan 21, 2004
    2,678
    Argent/Brasil
    Guido
    Just did'nt understand why the cams on that first picture dont look from a mondial.
    Guido
  10. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    It's from behind the back seat :) Cabs have an opening there to get to the cams other some other stuff. The black pipe is the where the oil dipstick goes in.
    Great work Nathan! Hope it will pass for you!
  11. ozmondy
    ozmondy Formula Junior
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    Nathan
    on the 3.0 there are "nicks" on the cam bearing caps that line up with the "nicks" on the cams .
    Very small bug def there if you look.
    I am lead to believe that same on both the 3.0 and 3.2
    Once you see what I talking about it falls into to place.
    I have mine out at the moment.
    Use the thread to show u TDC on the flywheel and go fro there...u should see the little marks I am speaking of
    Peter
  12. Nathan76
    Jun 20, 2013
    344
    Leicestershire, UK
    In for the test tomorrow.
    It's running very sweet.
    There are indeed the engine builders center punch marks on the cam shafts that align perfectly.
    It seems the timing plate fitted to the cam cover is mis aligned - I'm wondering if this is not an oem part....
  13. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I was wondering the same, but the look OEM to me.. The two are not equal so they could be switched. Best to do timing is to pull the cam covers actually. There are an additional set of notches. Have a look in to oil filler hole and look at the end of the cam shaft. Problem is you only have one hole :) Hope you will pass Nathan!
