Cam Variator failure | FerrariChat
Discussion in '360/430' started by OKA, Oct 28, 2009.
  1. OKA
    OKA Karting
    May 7, 2008
    217
    Houston, TX
    Sam
    I was at a Ferrari dealer yesterday and in the shop there was a 2000 360 with a failed Cam Variator. It was the updated variator and the car had 16k miles on the clock. A couple of bent valves and about $20k in damages.
    It might not be a bad idea to have these changed out with the major. Have there been many cars with these updated parts failing?
  2. DerWebMeister
    Aug 21, 2007
    119
    Columbus, OH
    Timothy
    I read that the variators were recommended to be changed at every belt change. What a disaster. I haven't seen miles between failure data, how far did the car roll, with the updated variator, before this failure occured? If an updated variator failed, does Hill Engineering make one that is more reliable?
  3. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I have seen a few report of the updated variator failure, never seen one failure of the old version variator. Seems like the updated variator has no advantage over the old one.
  4. OKA
    OKA Karting
    May 7, 2008
    217
    Houston, TX
    Sam
    I'm not sure how long after the updated variator the failure occurred. But dealer said it all of a sudden failed on a test drive.
    I wonder how much more it costs to change the variators on the belt change.
  5. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,631
    South East
    Jimmie
    #6 greyboxer, Oct 29, 2009
  6. DerWebMeister
    Aug 21, 2007
    119
    Columbus, OH
    Timothy
    I just read all of the thread. The upgraded variator failed. It was installed in April 2004 and failed in 2009, covering a distance of 10k miles.
    Are variators failing on 430's?
  7. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    Based on all I have read on this I am contemplating changing the variators every other belt service. Yes this is the second failure I have heard about in the past couple of months, but with the thousands of 360s made the probability of failure still seems very remote...it is unfortunate, but I guess if I do 4 year intervals on belts that works out to every 8 years...heck, I'd probably do them once during the whole ownership of the car.
    My car was updated unusually late (just last year even though its a 2000 model-year car) which works to my advantage as they are only 1 year old.
  8. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,293
    Colorado
    Dave
    I haven't heard of one. I bought mine new 8/05 and it now has 17K on it. There are no TSB's on it.
    Dave
  9. technom3
    technom3 F1 World Champ
    18,099
    Phoenix AZ
    Justin
    pretty sure that the 430 V8 has very very very little to do with the 360 V8. The 360 V8 if I recall is more of a modified 355 v8
  10. Rifledriver
    36,779
    #11 Rifledriver, Oct 29, 2009
    Variators are only $417 each but replacing them has often required replacement of the camshaft and those are about $1200 each and then there will be a substantial labor bill.
    You will run up the price of a service real quick.
    I think someone should be tracking failures so that a case can be made that Ferrari has not fixed a known problem. It has been done many times before.
  11. tazandjan
    39,028
    Brian- What actually happens when a variator fails on a 360? Logically, if designing one, a failure would just not advance the cam and only cost you a little power until repaired. I had a failure on the VVT solenoid on my wife's GL 550 Mercedes recently and all it did was give a CEL. Replaced under warranty with no damage to the engine. Without the CEL lamp, I would not even have known there was a problem.
    Taz
    Terry Phillips
  12. Rifledriver
    36,779
    The variator is functionally the part that connects the sprocket to the cam. It is a big male fastener that screws into the nose of the cam and the shaft breaks at the radius at the base of the threads. When that happens it quits driving the cam. There is a picture of a broken one in the other thread.
  13. tazandjan
    39,028
    Brian- Ouch. Designed in failure point. I looked at the photos. Must have been a hundred different ways to design that system so a failure was not catastrophic.
    Taz
    Terry Phillips
  14. hardtop
    Jan 31, 2002
    11,293
    Colorado
    Dave
    Brian,
    Is the 430 variator substantially different?
    Dave
  15. Rifledriver
    36,779
    Its design is not disimilar. I have not had one in my hand so I do not know if there were any detail changes to the shaft where the 360 piece breaks. They started having trouble with the 360's in Challenge racing first. I have not heard of trouble with the 430 Challenge cars but I am not very close to that anymore.
  16. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    #17 andrew911, Oct 29, 2009
    One thing I can think of with the way that variable timing mechanism appears to work would be to increase the diameter of the threaded part to give it more strength. I cringe to think of a motor going 1,000 rpm let alone 8,500 rpm when that part snaps and the pistons go crashing into whatever valves are partially opened at the time when the camshaft stops. Being as I doubt they can change the diameter of that part without changing the camshaft at a minimum or perhaps even more in-depth changes, the logical next thing I can think of is if we were lucky enough for the factory supplier or Hill Engineering to manufacture the same exact variator but made with a stronger metal if that's possible...
    This sucks- it seems to be a very rare thing, but it will always be in my mind unless a better variator is manufactured and installed in my motor!
  17. Ricambi America
    Sponsor Owner
    shhhhh....
  18. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,307
    Montana
    Kim
    #19 308 milano, Oct 29, 2009
    This might sound silly,.... but would it be possible to "x-ray" the shaft/gear in the car during each belt service similar to what they do to check for fatigue on an aircraft propeller?
  19. SonomaRik
    SonomaRik F1 Veteran
    is that the same Shhhh as on the front wheel bearings of F40, TR, and most all 3x8 series: The shhhh is like torture.
  20. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    Don't worry- your secret is safe with me- no one is reading this thread anymore :)
  21. tazandjan
    39,028
    #22 tazandjan, Oct 29, 2009
    430 looks very similar, but now you have twice as many chances for a failure because both intake and exhaust have VVT.
    Looks like a solenoid failure would not be catastrophic on this engine.
    Taz
    Terry Phillips
  22. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,642
    Anyone have any idea as to how much power it takes to turn one cam at 8500 RPMs?
  23. bizmarty
    bizmarty Rookie
    Oct 26, 2009
    5
    Hi Guys
    I am an Aircraft Engineer and have quite a lot of experience with mechanical components failing, looking at the 360 Variator I was shocked to see how small the threaded portion that screws into the cam is, also the oil way that runs through the centre reduces the amount of material there drastically! That combined with an over tensioned cam belt is a recipe for disaster IMO. I know your cam belt should be tensioned correctly but you will never know that really unless you do it yourself, or have a mech that is competent and that you completely trust. It is possible that if the belt is correctly tensioned that this failure will never occur, is it just an under engineered component...I think so…we will have to wait and see!
    It would be possible to have the Variators NDT’d (Non Destructive Testing) at a cam belt change but unless the fault was in there at manufacture, I don’t think you would see anything. If a crack is there I think it would of failed already, or you have been damn lucky!
    So I take it that there is not an upgraded Variator available at the moment? There should be if not!
  24. SonomaRik
    QUESTION: THe belt I believe has a self tensioner, so what changes would you make as a designer to repair this problem? You insights would be good, as NO one want an aircraft to fall out of the either.
    thanks
