Hi I have finally found and bought a 1987 GTS Turbo in Italy. The car is being fully serviced and having its cambelt/timing belt changed as well as the Timing Belt Tensioner Bearing changed. As parts were hard to source in Italy I have had to send the parts from the UK. I made the mistake of sending the Service Kit for 328 and the Cambelt/Timing Belt and Tensioner appear not to fit the GTS Turbo. Would anyone in the forum which is the appropriate parts for this model? Many thanks for your help! Luis
Thanks for the your help nerofer.....i will make sure that the cambelts that i send are for two-valve engine. It appears that the bearings are the same for both models though.
