Camel build | Page 15 | FerrariChat
Camel build
Discussion in 'Aviation Chat' started by snj5, Sep 17, 2009.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,109
    Southlake, TX
    Rob Lay
    LOL both you and I have been happy recently to get "pink slips. :D Mine was Aircraft Registration, is that what you have or is that Air Worthiness?
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
  4. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    And I guess it can land too, otherwise there would be no post from you ;)
    Great stuff. Enjoy carefully :).
    Pete
  5. Ricambi America
    Sponsor Owner
    Just shy of 11 months, and she's in the air. Absolutely amazing thread!!!! Been lurking the whole time, and Russ, I am speechless. Congratulations! Please, spend more time flying, and less time posting for a while. You deserve it !
  6. Gatorrari
    Gatorrari F1 World Champ
    16,481
    Georgia
    Jim Pernikoff
    Fantastic! Baron, you'd better watch out, 'cause Snoopy is in the air and after you! :D
  7. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    What a great picture. Just astounding what you have done in such a short time. Congratulations!
  8. rob lay
    Dec 1, 2000
    64,109
    Southlake, TX
    Rob Lay
    Russ, please tell us a little about the testing and initial flight. That appears to be you taking the picture and not flying. Convince some young and crazy freshly minted pilot to test? Well, they made the best heros and aces originally. :D
  9. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    That is so great! It looks perfect. Kudos but let's have a report on it.
    Switches
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #360 snj5, Jul 11, 2010
    Thanks so much everyone - many here had a direct impact on the little plane and were inspirational. I chose Harvey Cleveland to test fly the plane as he has over 20,000 hours, mostly tailwheel, and has test flown every Airdrome WW1 replica. He knows exactly what he is doing, is absolutely unflappable, and 20 minutes with him would reveal more than hours by me. I know my limitations and the plane's efficient and safe testing is the main priority here.
    Now for my buds, the nitty gritty.
    The Rotec R-3600 swinging a 90 x 48 Culver propeller, static rpm of 1750 rpm prop and 2650 engine - BIG CAVEAT - tachometer has not been double checked. While well down the 3600 rpm range, this produced a healthy 550 - 570 pounds of thrust. I feel pretty strongly that once broken in, and perhaps other tweaking, it will easily reach 600 pounds of thrust.
    With two electronic ignitions, it starts instantly. The throttle body injector is its own entity, and we are learning how to best use it. I STRONGLY feel it is superior to the stock supplied 40mm Bing carb. based on my limited experience so far. One trhing you do notice is that the Rotec 9 cylinder is much quieter than you expect, and very smooth. From the ground, vintage aviation author Eric Preston said it sounded much like a 80 hp LeRhone in the air.
    The Sopwith currently has provisions for brakes, but not hooked up. At just over 1100 pounds test AUW, it is no little light airplane and has some serious inertia to be managed on the ground. This test was on grass, but it will absolutely need brakes on any prepared surface. The steering tailwheel was wonderfully positive, and at least for us frequent flyers, a very neccesary compromise.
    On take off roll, not pushing the plane at all, the tail comes up smartly and the plane unsticks in about 400 feet. Climb out seems happy at 60 or so mph. We did not push the climb, but a normal climb rate of about 600 or so feet a minute was what it seemed. All of the controls were not neck jerking, but positive. One thing that impressed the test pilot the was the wide speed envelope of the airplane where no trim was needed; you just put it there and it stayed. I personally think this is probably attributable to the original Sopwith designers' mass concentration. For you technical folks, we have 1.5 degree wing AOI with 0 degree horizontal stab AOI, lower wing dihedral of 5 degrees and zero degrees for the top wing. The engine has a down thrust of 2 degrees. The test CG was about 24% MAC. Controls were described a sweetly harmonized and normal stick pressures - seems Sopwith got their control surface areas dead nuts on. Slips wonderfully. Did not do a full stall series this flight.
    At reduced power settings, the airplane would fly happily loafing between 80 - 90 mph at 1650 rpm indicated Lower the nose wee bit at same settings and it would easily pick up to 100 mph indicated. Again - these are indicated and not verified against an external source, but it was a new ASI.
    Approach was tried at 70 and 80 mph, both worked fine. When the power is pulled, the plane does not slow as fast as you think it might (inertia), bur settles gently down to the runway conventionally. Without brakes or skid, it had a loooong roll out (inertia) of about 1000 feet.
    We actually had a camera ship with Eric Preston on board, and here are a couple of photos. I think it's the best looking Camel replica flying, but I'm biased.
  11. Fastviper
    Fastviper F1 Rookie
    Nov 20, 2003
    4,525
    Texas
    Dash
    Congrats Russ.. It looks like a drawing..
  12. tazandjan
    39,252
    #362 tazandjan, Jul 11, 2010
  13. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    Russ,
    Congrats in getting it into the air... This is so cool!!!
  14. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Terry, did you acquire those sketches with a painting? What did the painting depict if I might ask?
    Switches
  15. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Man, you are going to have some serious fun with that bird. What a great looking airplane.
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #366 snj5, Jul 12, 2010
  17. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    Killer Russ. Absolutely killer.
  18. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
  19. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Yeah ! I just thought that my eyes were fooling me but at second glance at the video, you are correct, " The Barefoot Pilot in a Camel".
  20. Willybeen
    Willybeen Karting
    Aug 18, 2009
    238
    Vero/Palm Beach
    William
    absolutely wild... this is so cool..
    congrats on getting it flying...
    be safe up there!
  21. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #371 snj5, Jul 13, 2010
  22. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    We took the airplane apart today for a post flight inspection.
    1. Landing gear hinge pins replaced with larger, heavier duty pins,
    2. Modify proceedures to ALWAYS turn off the main fuel petcock as the TBI has enough head pressure in a full tank to weep fuel. If any interest I could write an entire post on what we have learned about the tbi
    3. Will proceed with brake installation based on test flight. These are heavy duty cable actuated drum brakes from a racing go cart to Aeronca heel pedals.
    4. Oil changed - looked ok. replaced with 3 gallons of Royal Purple full synthetic 20 - 50
    5. need new handle on sump oil drain
    6. Install Tiny-tach back-up tach/Hobbs on electrical sub panel to calibrate main tach. ($39.95!)
    7. Need baffling to provide cool ram air to oil cooler
    8. Better battery master disconnect switch
    9. Better fuel master petcock
    Am playing with idea of shaving the propeller down a couple of inches to try to get a couple more rpm into the power band.
    We are also outfitting the 20 x 8.5 x 10 foot enclosed trailer with carpeted wing storage racks. Painted in black with a prominent V nose, she looks like the Titanic. She will make her voyage to Texas hopefully all safe.
  23. tazandjan
    39,252
    Bob- Jasta 19 attacking 48 Sq.
    Russ- Great shots.
    Taz
    Terry Phillips
  24. Kds
    Kds F1 World Champ
    Russ.......
    Congrats !!!!
  25. ApexOversteer
    ApexOversteer F1 Veteran
    Feb 15, 2007
    5,968
    Smoky Mountains, TN
    T.A. Bell
    Been watching the build for a while and this has been one of my favorite threads on F-Chat this past year. Congrats to snj and thanks to everyone else that contributed excellent posts!
    We do need more pics though... :D
