Camshaft oil seal replacement: How? | FerrariChat
Discussion in 'Mondial' started by schelle_pelle, Dec 22, 2022.
  1. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    202
    Berlin, Germany
    Hi,
    I am doing a major service on my '86 3.2 and have the camshafts removed in order to reseal everything and do the valve clearance adjustment.
    I am really struggeling to get these oil seals out of the alloy ring. Is there any smart procedure? I have watched videos and read threads but I am getting the impression I am the only one struggeling. The difficulty for me is to put the right amount of force to the right place. I bet these are the original seals from 86, except one brown seal that must have been replaced somewhen.
    Any help appreciated!
  2. Tegethoff
    Tegethoff Formula Junior
    Jul 19, 2014
    301
    Los Feliz
    Adam
    #2 Tegethoff, Dec 22, 2022
    Support the ring on a suitable sized hollow cylinder in green ( pipe, socket, etc)
    Drive against the back of the metal face with a punch/chisel/screwdriver and hammer in red, be sure to get behind the lip seal, or just cut the lip out completely. Small taps in rotation around the seal, a little bit at a time, if you force the seal unevenly it may distort the ring.
    Ring in blue, punch in red
    Since you have the cams out, you could also reinstall the ring on the engine, clamp it down with the valve cover and the pry them out from the front.
    moysiuan likes this.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    If all else fails, machine them out on a lathe
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Put it in a vise, use the seal remover to pull out the seal.
  5. schelle_pelle
    Oct 22, 2021
    202
    Berlin, Germany
    That was the solution! It took a while to get the right "tool" to put the camshaft ring on. I found a 70mm in diameter ring from the food industry for food decoration. I german it is called "Schaumspeisering" :-D.
    I secured the camshaft ring with a zip tie to the ring and put a screwdriver in the oil seal and hammered it out. Very satisfying work... :-D
    ellum, moysiuan and Tegethoff like this.
  6. Tegethoff
    Jul 19, 2014
    301
    Los Feliz
    Adam
    Congratulations, glad I could help.
  7. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,671
    Argent/Brasil
    Guido
    Nice SKF video how to = oil seals
