Camshaft Position Sensor and PPI results. | FerrariChat
Discussion in '348/355' started by recoil, Nov 9, 2007.
  1. recoil
    recoil Formula Junior
    Sep 7, 2007
    461
    Virginia
    Steve
    Had a PPI done on a 355 yesterday. Overall, everything looked great per the technician.
    Here are the #s on the engine:
    Cylinders 1-7; 10%, 8th cylinder 5%.
    155, 160, 160, 160, 155, 150, 160, 170
    Only one weird thing happened. After driving, the c/e light came on. They pulled the code. It was "camshaft position sensor". They reset it and it went away and didn't come back. The owner said it would intermittently do that.
    They also recommended replacing all the plugs (it wasn't done at the last 30K) and indicated the brakes were louder than normal (saw new pads).
    Any cause for concern on the camshaft sensor error? Hard/easy fix?
    Steve
  2. billyfitness
    billyfitness Formula Junior
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    The plugs weren't swapped out during the major??? That's crazy. Probably the easiest and cheapest thing to be done along with the plug wires.
    The Cams should be, (should have been), timed as well. Someone had a recent post about that not too long ago. It made a huge difference in my car. Any frequent and reoccurring error code should be approached with caution. The mechaincs and more experienced thatn I on this board should be able to answer the sensor question.
    -Billy
  3. recoil
    Sep 7, 2007
    461
    Virginia
    Steve
    Fernando with Competizione just told me the compression numbers were too low and with 31K on the engine, he recommended I keep looking.
    Had another guy say it's not the height of the numbers but the consistency or difference between the cylinders.
    What do you guys think?
  4. FullChat
    FullChat Formula Junior
    Jan 1, 2007
    339
    San Antonio, Texas
    IIRC, the specs are 150 psi minimum and less than 10% between cylinders. The spread on this car is over 13% and some of the cylinders are at 150 psi - bordering on busting that end of the spec.
    I'd keep looking (or budget for a rebuild).
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    It is not in the best of shape..... not changing the spark plugs at a 30k shows they skimped.... now its a matter of how much they skimped :(.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The cam sensors are an easy, 15 - 30 minute, fix that you can do yourself.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Camshaft sensors are about as easy as it gets.
    Compression numbers are subject to a lot of variables depending on the methodology. It may in fact be fine.
    It would have been convenient to do the plugs when the compression test was done. Not a big deal though.
