Camshaft Position Sensor | FerrariChat
Discussion in '308/328' started by steve0826, Dec 19, 2009.
  1. steve0826
    steve0826 Karting
    Jul 13, 2009
    123
    Bellevue, WA
    Hi Everyone,
    I have two questions about camshaft position sensor:
    1. Can one used for 308 work for 328?
    2. Is it necessary to replace both together?
    That's it. I will not bother all of you with the other details.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,735
    The twilight zone
    I'm sure a 308 does not have a camshaft position sensor and I don't think a 328 does either.
    Do you mean the crankshft position sensor? If so I think the 308/328 sensors are the same but the plug on the end is different....I think.
  3. steve0826
    steve0826 Karting
    Jul 13, 2009
    123
    Bellevue, WA
    [Correction]
    It is crankshaft position sensor. Sorry.
  4. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    They are flywheel sensors and I am quite sure the 308s will fit the 328s. The 328 only has 1 TDC sensor vs 2 TDC sens. on the 308s. I prefer to replace both TDC sensors at the same time just because it is easier while you are in there but you don't have to replace them at the same time. So no you don't have to replace them together.
