camshaft removal | FerrariChat
camshaft removal
Discussion in '308/328' started by jon s, May 31, 2014.
  1. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    if i ever have to remove the shafts is there anything special about the job. it looks straight forward, but everything does until you start doing it. i did a number of searches but didn't find anything. thanks, jon s
  2. Ehamilton
    Ehamilton F1 Rookie
    2,644
    Durham, NC; USA
    Eric Hamilton
    You have a two-valve injected car, so it's pretty easy. The only pitfalls that I found, assuming that you already know how to get things apart enough to change the belts and check the valve clearances:
    - Put the motor on PM1-4 before you start, so you can check the position of the camshaft marks against the marks on the cam caps. Do this before you take the belts off, of course.
    - Pay attention to the position and orientation of the caps (five for each camshaft); they have to go back in exactly the way that they came out. Mark them with a sharpie before you start removing them if you have any doubts. (The stamped markings on mine were inconsistent, which caused me a sleepless night reading threads about seized camshafts).
    - Plug the spark plug holes and intake manifold runners with rags or paper towels so you don't drop anything into them. Do the same for the oil return ports in the head as soon as you have the cam covers off.
    - I wouldn't try this without removing the decklid first.
    - Lay in a stock of high-quality 6mm (1/4") Belleville washers for the cam caps, and you won't have to feel guilty about reusing the old ones if they look flattened.
    - Do not cheap out on your torque wrench. The cam cap nuts want 9 N-m, much too little for a cheap/oversized torque wrench to do accurately... and this is a place where it really matters.
    Doubtless others will have more, but that's pretty much my list.
  3. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
  4. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    thanks guys that was very helpful. i've been warned that you have to undo the cap nuts in small increments to avoid cracking anything. what do you think? jon s
  5. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Yes, that is true. I took detailed notes when I removed mine. If you want a copy of my notes PM me. I have a 2V carb car.
  6. Ehamilton
    Ehamilton F1 Rookie
    2,644
    Durham, NC; USA
    Eric Hamilton
    Well, I didn't try something else just to see if the caps really would crack :) but fastening and unfastening in small increments is always good practice for stressed assemblies... I can't imagine wanting to do it any other way.
  7. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,305
    Ventura, California
    Robert Garven
    #7 robertgarven, May 31, 2014
    Put the caps all in a numbered box and put them back on the exact same way unless they were wrong. The Previous guy that worked on mine left several of the alignment dowels out I found one in my lower oil banjo fitting.....
    also number the shafts on the bolt 1234 that helps
  8. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
  9. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    thanks again, got the message. fear can be a good thing. jon s
  10. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    If you get the caps mixed up by any chance, the heads and caps all have corresponding numbers stamped into them.
