Camshaft Rotor Coupling Orientation Help | FerrariChat
Discussion in '308/328' started by samsss, Apr 25, 2024.
  1. samsss
    samsss Karting
    Apr 17, 2021
    67
    Sam S
    In my haste to remove the couplings to replace the O ring, I forgot to mark the orientation to where the flat side of the coupling sits (the part the rotor fits on to) with regards to the camshaft. In this picture the couplings are lined up with the pin holes, but I don't know if this is the correct orientation, or if one or both of them should be rotated 180 degrees. Any direction/help greatly appreciated. Thanks in advance!
  2. samsss
    samsss Karting
    Apr 17, 2021
    67
    Sam S
  3. Rifledriver
    37,106
    Lay the cam in the head at TDC for that bank figure out where #1 is on the cap and make the rotor point that way. There are 2 choices, hugely different. Will not be hard to figure out.
    waymar and Steve Magnusson like this.
  4. samsss
    samsss Karting
    Apr 17, 2021
    67
    Sam S
    Thank you so much for the reply! Greatly appreciated
