News
CAMSHAFT SEALS LEAKING, ENGINE OUT ?
Discussion in 'Technical Q&A' started by Rosso Corsa, Apr 9, 2009.
  1. Rosso Corsa
    Rosso Corsa Karting
    Jan 24, 2006
    101
    No.Fork Long Island
    Lee
    1987 328 GTS, does the engine must be removed to replace leaking seals!
  3. Eagle1
    Eagle1 Rookie
    48
    Wisconsin
    Mark Poulter
    Engine removal is not required for cam seal replacement in the 328.
  4. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,288
    great opportunity for some housecleaning ?
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    20,700
    Fullerton, California
    Jon
    +1
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,233
    Definitly not. If you are getting all the CSO seals done it might make sense to get the valve clearances checked while they are in there though.
  8. Scuderia P1
    Scuderia P1 Formula Junior
    518
    Monarch Bay, Calif
    Chris Conti
    #6 Scuderia P1, Apr 9, 2009
    Do yourself a favor and get some of this sealer...threebond 1211 liquid silicone gasket.
  9. FerrariEngineer
    FerrariEngineer Karting
    85
    ww.exoticars-usa.com
    Serkan Ozsavasci
    #7 FerrariEngineer, Apr 10, 2009
    Definitely you can do it
    _________________________
    - Courtesy of Exoticars-USA-
  10. 335s
    335s Formula Junior
    Jan 17, 2007
    869
    SF Bay Area
    T. Monma
    10-4 on the cement...allow as much time as is possible for set up as it will remain "soft" for several days...it will heat cyle harden quickly, so letting it sit for a number of days is best prior to "running" it in, so to speak.
    If tension on belts are relaxed, they must be replaced, cjeck play in lower drive bearings for belts-frequently they become noisy subnsequent to belt replacement... OEM tensioner bearing replacement has been my MO over the years from a purely safety perspective.
    On the oiul seals, this iss all for naught should you NOT perform the oil hole drilling modification-there is a factory tool for this, check with your local professional practitioner, as he WILL almost certainly, have it. It is done to all 4-valve cars(allows the oil which puddles behind the seal to drain back ito the drain galleys.)
