can a coil have a short and still work? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Pantdino, Jan 4, 2011.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    The green wire of your rev limiter should be the pickup wire going to the points, not to +12V. Would leave that unconnected until we know whats wrong with the setup.
    Would be great if you can test the optical pickup/XR700 by putting the Dino in the fourth gear and push it a bit forward to move the rotor position in the distributor pickup. If the ammeter stays on about -10 ampere then something with the Crane pickup or input stage is defective.
  2. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I checked the voltage regulator outputs again--
    With the new regulator from Fiat Plus (fits Fiat Dino),
    Ignition on and engine off: terminal 67 (alternator field) 10.0v, terminal 15 (battery) 10.8v
    Running at 1700 rpm with lights off: 12.3 and 13.1
    Running at 1700 rpm with lights on: 11.5 and 12.3
    With old regulator reinstalled:
    10.3 and 11.2
    12.3 and 13.1
    11.0 and 12.0
    Today at 3000rpm with lights off with the old regulator: 11.8 and 12.8-
    Two weeks ago I had 13.5 and 14.3v at these terminals with the same voltage regulator at 2000 rpm.
    Is the alternator dying?
  3. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Ignition off & 10.8V, thats a bit low, looks like your alternator is not charging your battery properly. How old is the battery?
    Ignition on, would expect 14.0-14.2 Volts battery voltage above 1500-2000 RPM.
  4. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    ahlbhn,
    I started a new thread entitled "Is my alternator dying?" when it appeared that the alternator was the problem.
    I think it is
    Thank you for your help
  5. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Jim, you're welcome! I think these are two separate issues, though (alternator not delivering full current, ignition switching on coil even independently of rotor position).
  6. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Adrian,
    I think the distributor / ignition is OK
    The optical sensor disc on the distributor shaft is basically a round, flat piece of plastic with 6 thin slots in it corresponding to the firing positions of the 6 cylinders. The lightbulb sits above the spinning disc and the sensor below it (or the opposite.)
    When the sensor is not seeing the light it is the equivalent of when the points are closed and power is going to the coil. The moment the sensor does not see light is the equivalent of the points opening-- the system cuts power to the coil and the field collapses, causing the spark.
    Looking at a photo of the disc, only maybe 5% of the surface area is slot, the rest being solid. So the chances of the engine stopping with a slot exactly between the light and sensor are very small.
    Hence the coil is energized when the engine is stopped.
    Or am I misunderstanding something?
    Jim
  7. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Thats exactly how the pickup works. The test with pulling the Molex connector/pushing the car was to make sure that the sensor circuit/pickup is indeed ok. So with a bit of luck your Dinos problem will be fixed with an alternator overhaul already.
  8. Steve Magnusson
    27,021
    (On reflection) I believe that there has to be a bunch of other electronics between the detector and what the primary coil current is doing (so it probably shouldn't matter where the optical wheel stops). Although the slot in the trigger wheel initiates the firing (or end of firing) event, it can't be controlling the primary coil current directly. The sizes of the slot and blocked off areas do not correspond to the dwell and open sizes that a coil needs to function -- just a thought...
  9. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Crane's XR700 looks like a classic two stage transistor circuit with an input transistor for the optical switch, which then controls a larger power transistor for switching ground to the coil. This approach is identical to Lumenitions Optronics ignition made in the UK. Both units have fixed dwell, e.g. the distance between the slots in the trigger wheel define the dwell degrees, which is the same for all engine speeds.
    This was the standard with early transistorized ignition in the late seventies, but around the mid eighties features such as dwell control and coil current limitation were quite common. This new generation of ignition controllers did not apply any current to the coil until the first trigger event came in (keeping the coil cool until the starter was turned) and tapered off the current 2-3 seconds after the last ignition trigger to avoid burning out the coil.
    Pertronix's Ignitor I has the same restrictions, although it uses a more modern IGBT transistor the dwell angle is still static and depends on the distance between the trigger magnets, also there is no automatic switch off or current control.
    The up market versions offered (Crane XR3000, Performance Optronic, Ignitor II/III) do have features such as variable dwell, automatic current switch off and current control, so it seems the manufacturers want us to spend more money for standard features...
  10. Steve Magnusson
    27,021
    #35 Steve Magnusson, Jan 11, 2011
    Got your PM Adrian, and no worries (I had to step out so I deleted that message because it wasn't quite right, and I didn't have time to fix it).
    My point is that the ratio between the open and closed areas in the Crane optical wheel does (can) not directly represent the ratio between the dwell (time when current is flowing in the coil primary) and the time when current is not supplied to coil because they are just so different in size. I can certainly agree that the detection of each open slot (I'm not sure whether it's the leading or trailing edge) initiates the process where transistor(s) switch the primary coil current on and off, but I can't yet agree that current flow in the coil primary corresponds directly with what's happening at the optical switch -- do you see it differently (or did I misunderstand your post)?
  11. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    #36 alhbln, Jan 12, 2011
    Steve,
    i believe that the Crane XR700 trigger wheel/transistor switch setup is a simple electronic adoption of the classic points mechanism. Crane mentions in their sales collateral that the XR3000 contains "a computer chip that controls coil current and dwell", but these feature are not listed for the XR700.
    The XR700 switches ground to the coils primary winding as long as the rotor blade covers the led in the optical switch (dwell phase). On the leading edge of a slot, ground is removed from the coil (discharge phase).
    I fully agree that the trigger wheels covered area looks out of proportion compared to the slots, but please have a look at the drawing i have attached. The black outline is a six cylinder trigger wheel supplied by Crane and the blue outline the cam of a S125C Dino 246GT distributor. The dwell area of the trigger wheel seems to be pretty much in line with the original cam's dwell phase, so i guess there is not much difference between the cam and the trigger wheel regarding dwell.
    Regards,
    Adrian
  12. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Wow,great work, Adrian.
    So I should be careful to not leave my ignition on with the car not running.
    I like the idea of a computer chip providing a failsafe in one way, but it is also one more thing that can fail and leave me stranded somewhere.
    I wonder if I could buy an XR3000 and plug my connector from my 700 distributor sensor into it.
    thank you,
    Jim
  13. Steve Magnusson
    27,021
    #38 Steve Magnusson, Jan 12, 2011
    Can't agree with your drawing Adrian. The portion between the two dashed red lines on your drawing does not represent where the points open and close on the dist cam -- they represent where the points are held fully open (constant radius from the dist axis). Additionally, the 246 US OM specifies a point opening angle of 28 deg and a point closing angle (dwell) of 32 deg. The coil doesn't know if a set of points is switching the primary current or if a transistor is switching the primary current, so these values should be about the same for either system. Consequently, I still conclude that the slit on the Crane wheel initiates the firing event, but it's size does not correspond directly to the length of the discharge time.
  14. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Steve,
    sorry for the confusion, my drawing was not meant to convey the exact dwell angles but to compare the functional aspects of both approaches. I am not too worried about the different dwell, as the dwell charge time in a fixed dwell setup is defined based on the target coils properties (inductance, primary current handling and saturation time), so depending on the components and application closing angles vary can from 30-38º for 6 cylinder engines.
    What i tried to show was that the trigger wheel is not so far off from the original points and cam approach regarding dwell and discharge phase. The XR700 does not seem to be able to correct dwell, it simply supplies ground to the coil based on the trigger wheels design.
    regards,
    Adrian
  15. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Leaving your ignition on will heat up the coil/XR700 and drain the battery a bit but as long as you don't leave it on for more than 5-10 minutes there shouldn't be a problem. If you want to play it safe, you could add a 0.9 Ohm Resistor to your 1.7 Ohm coil to keep the current below 5 ampere (the XR-700 datasheet lists 4,5 ampere, you are running it at 7-8 ampere with your current setup).
    The XR3000 looks good, you could use the same pickup, have current/dwell control and its quite affordable, but as long as the XR700 is ok and delivers you don't really need to spend money, IMHO.
  16. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    When I did the "Do you have a ballast resistor in the system?" test on the Crane site by grounding the neg coil terminal and measuring voltage at the pos terminal, I got 7.58 volts.
    Crane said < 8v means you have a resistor.
    Do you agree with that?
    Jim
  17. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    Hmm, thats such a small difference that it could be just the resistance of the wiring leading from the battery plus terminal to your coil. Try this test instead, remove the +12V wire connected to your coil's plus terminal, and measure the resistance between the +12 wire you just removed and the battery's plus terminal. You should see less than one ohm without ballast resistor or >2 ohms if there is a ballast resistor in line
    Your measurement of the coils primary resistance with all wires removed resulted in 1.7 ohm, correct?
    P.s. if your +12V wire going to the coil's plus terminal is yellow then it is most probably the original wiring coming from the ignition key and has no ballast resistor in line.
  18. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I meant that I got less than 8V under the condition specified, which according to the website means I have resistance in the line.
    Yes, I measured 1.7 ohm in the primary circuit
    I don't think I can measure the resistance between the battery, which is in the front trunk of the car, and the coil, which is in the rear trunk / boot.
    Yes, the wire is yellow. But I'm thinking that doesn't mean someone didn't splice a resistor into it somewhere.
    Jim
  19. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    The 7.58 volts you got in the Crane test indicates a resistance of 0.6-0.7 ohms, this is just the resistance of the wiring coming from the fuse block/ignition key. With a ballast resistor in line you would see a voltage around 4-6 volts in this test, so i am pretty convinced there is no ballast resistor in your setup.
    regards,
    Adrian
