Can a ipod be hooked up to the stock stereo | FerrariChat
Discussion in '348/355' started by Marcelo0131, Nov 11, 2009.
  1. Marcelo0131
    Marcelo0131 Karting
    Oct 14, 2009
    90
    Stanton, CA.
    Marcelo
    I did a search and only found complete radio upgrades. I only would like to hook up my ipod and maybe a new speakers. I don't mind loseing the cd changer.
    Thanks for the help
  2. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    Your best bet (sans replacing the headunit) will be to go with a wireless FM transmitter, you can combine this with a car charger to keep the ipod charged up. You do loose a bit of sound quality with the transmitter but the more you pay for it the better it should be.
    I went with an upgrade of the head unit to a Alpine that has ipod controller built in. Works great!
  3. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I use the Griffin Itrip FM transmitter. As long as you keep it plugged into the cigarette lighter, it works great. It can also run off of the iPod battery, but the reception is not as good.
  4. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,792
    Henderson, NV
    Roberto Bellezza
    I have installed one of those Sony Xplod in my car and include the direct drive for the Ipod.
  5. Night life
    Night life F1 Veteran
    7,113
    The city that rhymes with fun in Canada
    Roberto
    #5 Night life, Nov 12, 2009
    Yes you can hard wire it in by removing the audio out from your cd changer, not sure if yours would be RCA if so just buy the proper attachment cable that plugs in to your headphone out, make sure it has female RCA ends and just connect. You wont be able to control your Ipod from the car stereo just the volume.
    If you do not have RCA audio out then you must find the hardwired wires for the audio out and do some splicing if you are a handyman :), it's not that difficult.
    Or just buy a FM transmitter, although most out there suck and are not as good as wiring it in.
  6. TRScotty
    TRScotty F1 Rookie
    Oct 12, 2006
    2,505
    Tyler, Texas
    Scotty
    For the sake of all that is Holy, it is a Ferrari!!!!!!
    You don't need no stinkin' radio!!!!! Or iPod, for that matter.
    Tubi, and forget it. :D:D
  7. Night life
    7,113
    Roberto
    Amen ;)
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,281
    South East
    Jimmie
    If your radio is the Becker with the blue plugs its easy to replace the CD changer with an Ipod cable but as noted above you will not be able to control the Ipod only recharge (& play - depending on the cable) - there's extensive instructions in the 360 section (thread 243921) - the expensive cable has two plugs to go into the radio (sound & charge) - there are two types of cheaper cables that work - one without charge and one that has to be hard wired into the loom
  9. DurandDurand
    DurandDurand Rookie
    May 27, 2006
    32
  10. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,506
    Somewhere, anywhere
    Eddie B
    The original Sony unit has RCA's from the C.D changer, but there are aftermarket units that plug straight in and also supply a feed to keep the ipod charged. As others have said, however, direct control will be from the ipod not the head unit. The early beckers as fitted to 360 is just a plug-in job as it has ISO connectors, and the later ones have total control from the head unit rather than the ipod. The latest version of ipod adapter from Becker is having serious issues with backround noise, i've had to change a few now (part no. 1860.168 is the culprit). An FM modulator as others have suggested will work fine too.
  11. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    156
    Gulf Breeze, Fl
    Craig Payette
    I would take my stereo out, if it wouldn't look stupid. I never turned it on, and I never will. I want to be able to hear absolutely everything that is going on in that engine bay.
