Can a leaking 308 oil cooler be repaired? | FerrariChat
Discussion in 'Technical Q&A' started by jm3, Mar 28, 2004.
  1. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Or should I throw down for a new one?
    I understand this is not uncommon.
    Jay
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    I would say any decent radiator shop can fix the oil cooler MUCH CHEAPER than getting a new one. Just tell them it's for a Fiat or something, not a Ferrari.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Ditto, just look up a truck radiator rebuilder.
    Just as good(actually probably higher quality work) altho likely a bit more $$ would be a company that rebuilds aircraft radiators & oil coolers.
  4. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    #4 Peter, Mar 29, 2004
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I dont know if its the same as the 328 but last year my cooler was leaking,so i took it to COOLEX in Derby in the UK. They told me they were reluctant to try to fix it and garante it, becourse they were hard to fix. I took it to Shiltec Ferrari whos rad guy said the same,so i had to buy a custum made one becourse Ferrari had no stocks in the uk. I see that people say fixing them can be done but this is what my expereance was of the oil cooler.
  6. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,305
    Ventura, California
    Robert Garven
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    I have never been able to find anybody locally who would agree to fixing an oil radiator. Coolant radiator, yes, but not oil coolers. I always ended up having to buy a new one.
  8. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    if the oil cooler is aluminum the only option is to try to use epoxy. It will work sometimes but it depends on the location of the leak.
    aluminum is almost impossible to weld or solder when it's really thin like a radiator.
    back in the day, radiators were made of things like brass and copper and could be easily repaired using solder, but now radiators are using plastic tanks and aluminum fins and tubes, so if an epoxy repair will not hold, replacement is the only option.
    I would suggest if you are going to go the custom route, get it made from brass and/or copper so it can be repaired if that time comes again.
  9. fatbillybob
    Aug 10, 2002
    29,026
    socal
    david's radiator wilmington california
  10. robertgarven
    Feb 24, 2002
    5,305
    Ventura, California
    Robert Garven
    #11 robertgarven, May 25, 2012
    Freinds,
    I send my radiator to a high end aircraft shop in Los Angeles , Pacific Oil Cooler Service Inc., who are very cool, and I cannot believe they would even look at my cooler but they are a great and the gentleman I talked to was very kind. They are not sure they can repair it but here is a pic of the leak. The GT one is nice but since my shroud will not fit it I am looking for a used shroud to modify. If anyone knows of some one parting out a GT4 let me know. I almost bought another Ferrari oil cooler to see if it would fit and Daniel is looking for one. It seems the original 106965 was replaced by 145712 which was replaced by the GT Car Part one 114734. And as it seems over the evolution of the part it changed jeu enough not to fit.
    For those of you who are interested the GT4 had the same il cooler through its life 106965 however sometime between 1975 and 1979 when the shroud part 107131 was exhausted it was replaced by a shroud 107891 which did NOT have the winter cooling flap. I got an email fro Superformance saying that all they had was the original cooler and it should work but the pic on their site is very different from my OEM. here is a pic of the leak and Superformance cooler...
  11. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Robert; Ferrari UK stocks the very same cooler.
    And it fits: I have one on my GTB. The only necessary thing was a slight modification on the duct, because the distance between the fittings is different ( smaller ). I don't know, whether this is also necessary on the GT, but I think so.
    The manufacturer of these coolers is AKG. Formerly founded in Germany, they are now over the world today.
    http://www.akg-of-america.com/
    Best Regards from Germany
    Martin
