Can anyone recommend an engine cradle/stand | FerrariChat
Discussion in '308/328' started by stevel48, Jul 26, 2015.
  1. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    Looking for a cradle to hold the complete engine during an engine out major. Clutch housing will need to stay on. Are there any good universal ones?
    Thanks.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    I just made one out of some 4x2. Big castors underneath so it's mobile.
  3. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    #3 Mike Florio, Jul 26, 2015
    I made mine out of 4 x 4s, Gorilla - glued and screwed together. All you need is a chop saw and a drill. You can get at everything you need to get at, even the oil pan. Mine is only 18" high and I should have made it maybe a foot taller - it would have made it easier to get at the oil pan. The 4 x 4s on the top rails were needed to clear the differential housing
    I had rotating casters on mine, secured to the bottom with 1.5' lag bolts. When the weight of the engine was placed on it they rotated outward and ripped out. If you are going to use casters I would suggest you use fixed casters and bolt them through the wood and use big fender washers and nuts to secure them.
    PM me with your private email and I'll send you more photos and dimensions. Or you can go to this thread and see them: http://www.ferrarichat.com/forum/308-328/458208-observations-gt4-engine-pull.html
  4. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Great design. I may weld one up though using your wooden one as teplate.
  5. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    For the cost of the one on ebay you could get a real nice hydraulic lift table that is on wheels. I have 2 of them and have found them to be very, very useful. I also made two steel bars that lock the scissor wheels in place once the load is lifted up, takes the strain off the jack seals, also provides a lock-out in case it decides to let go!
    The only downside to supporting the lump on the supports is that you can't take them off to clean out all the yrs of road gunk and oil that cakes in there.
    THe neatest table I ever saw was one where the engine was supported over a metal grate with catch pans underneath. it allowed for the hardware to get caught yet the oil & water flow thru. it also rotated the engine via a reduction geared hand-crank. Custom built job, real nice and if you're building motors as often as the guy who had it, it made total sense.
  7. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    But can you torque everything if it's on a table and not bolted to a stand?
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    No problem.
