Can cabin vent fans blow cool outside air, with A/C off? | FerrariChat
Discussion in 'Boxers/TR/M' started by EricJF, Sep 25, 2015.
  1. EricJF
    EricJF Rookie
    Aug 3, 2015
    23
    Manhattan, NY
    Eric Friedman
    I don't know if this is functioning as intended, but I can't seem to have the cabin ventilation fan on, the temp knob in the blue 'cool' zone, and simply blow outside air into the cabin without the A/C adding cold air.
    This seems to be the case whether the 'ventilation' or the 'climatized' button is pushed in.
    Any suggestions?
  2. ago car nut
    ago car nut F1 Veteran
    5,497
    Madison Ohio
    David A.
    The only way I know of is to put a cut off switch going to the A/C compressor clutch.
  3. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,294
    NYC. / E. Hampton
    Michael
    Funny I have same incident in my 512TR..
    That thermostat dial knob has a click when the compressor is supposed to turn on...but its either hot air or cold air..assisted by compressor ac air..
    it is prehistoric planning of ventilation
    Perhaps Ferrari did not want windows fogging up
  4. N17RO
    N17RO Formula Junior
    Apr 9, 2013
    260
    UAE
    Craig
    Surely it's just a case of selecting the fresh air button then adjusting the dial to get you the desired temp coming out.
    If it's blowing just constant cold regardless of the temp setting then it's not operating as intended.
    Steve M took me through some diagnosis info to test the sensors, thermostat settings and ECU to determine what was wrong with mine as it was stuck on a medium setting then wouldn't give heat. Check my AC thread and you'll see all Steve and others help. It was good to go through all these and they were very easy to do.
  5. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Unfortunately you get A/C or heat. By design there is no fresh-air ventilation system.
  6. N17RO
    Apr 9, 2013
    260
    UAE
    Craig
    The system can draw fresh air through it, check the manuals! Most cars will still apply their AC or heaters to meet the drivers selected temp.
  7. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    I think Tim is correct. You can get fresh air, but the fan has to be running.
