Can copper plumbing tubing be used as fuel line? | FerrariChat
Discussion in 'Porsche' started by bpu699, May 3, 2007.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,714
    wisconsin/chicago
    bo
    I know, I know...you probably think I just became a hillbilly :). Bare with me.
    I am doing a rolling restoration on a 914. The car has lots of old plastic 5/8's or so fuel line. The Line is used where ever the line passes through bulkheads/firewalls/etc.
    I can't find plastic fuel line. I bought stainless steel line, and bending it is an absolute pain. I figured if plastic was OK, copper should be fine. I can also paint it to prevent a galvanic reaction should it come in contact with steel/iron.
    Would this work? Any reason why not?
  2. Kjell
    Kjell Karting
    Nov 3, 2003
    56
  3. t walgamuth
    t walgamuth Formula Junior
    Mar 13, 2005
    850
    copper is too soft. it will fracture under the vibration of an engine. i have used sections for vac lines but you don't want to use it for fuel because of obvious problems if it fractures there.
    steel is what you want. galvanized.
    tom w
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,342
    Dumpster Fire #31
    SMG
    not a good idea, non-ferrous metals work harden and will crack over time. stainless a real pain to bend or steel, however any water in the lines will rust it out. the other option which can be pricey is earls/russel fittings. they have bulkhead ones and then you just switch back over to barb or hose ends.
    for the odd stuff give a call to Jim at Mesa Performance or check the website. he knows his stuff and could most likely get what you need.
  5. -FROG-
    -FROG- Formula Junior
    839
    Austin
    Paul Daniels
    Also, copper is the best conductor for heat, so it may get hotter faster? Just throwing that out there, but not sure if it's valid....
  6. bpu699
    Dec 9, 2003
    17,714
    wisconsin/chicago
    bo
    Alright, I got some SS lines and used those. Needed to get some tube benders and a tool set for flaring the ends, but it looks great :) .
    Thanx
