Can I put a used ECU in a 360? | Page 2 | FerrariChat
Discussion in '360/430' started by MiamiPoker, Oct 23, 2014.
  1. GWARREND
    GWARREND Formula Junior
    Sep 23, 2012
    547
    Ontario, Canada
    Greg
    I used it for three weeks til I sourced a 3 pedal ecu. Yes..cel light
  2. tazandjan
    39,024
    Good info on just the CEL light, thanks. Many hard faults on the F1 system will set the CEL, but the CEL can be reset. Next time you start, though, on she comes. Just useful if you need to get a smog inspection. Reset and do not shut her off. I know from experience.
  3. zipperkarting
    zipperkarting Formula Junior
    256
    Jersey & France
    paul troalic
    So what you guys are saying is that it is not necessary to have a PIN matched to a replacement alarm unit you are fitting to a car. The replacement unit will pick up the PIN from the old unit?
    Yes?
  4. tazandjan
    39,024
    Paul- If you have a virgin ECU, correct.
  5. MD355
    MD355 Formula Junior
    Mar 8, 2004
    802
    Athens, Greece
    MD
    I've been reading this thread carefully, and I wanted to ask you the following :
    I have problems with my car and we have tried everything without luck..
    The car seems to have rough idle, it hesitates to rev when cold, backfires through intake, doesn't pull as hard...
    I have checked timing with degree wheel, replaced MAFs, Oxygen Sensors, Ignition Coils, Spark Plugs, all air intake gaskets and even tried another set of throttle bodies...
    Nothing...
    So I was thinking of changing the ECU to test and see if that's the problem...
    What should I do first ? Does it make any sense to switch sides on my own ECU ?
    (no error codes whatsoever)
    Do I need 2 replacement ECUs or 1 to do my test ?
    From what I read , the passenger side ECU should stay in the car and I need to find "virgin" ECU for driver's side... Can I borrow it from another car, or do I need to buy a blank...
    Also , my car is manual
    So , do I need to borrow manual ECU or can I do the test with F1 ECU ?
    How do I test passenger side ECU ??
    Do I put my driver's side ECU to right side and put new ECU on driver's side ?
    Thanks !!!!!
  6. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    Get it on a Leonardo and try to get a proper diagnosis.
    Did you ever get that timing issue, (degreeing) sorted.
    Last I heard it was off.
  7. mello
    mello F1 Veteran
    5,441
    CA Bay Area
    Steve
    You might as well throw in new fuel injectors, cam position sensors, crankshaft position sensors to complete the list. Afterward, tell us what's the ECU error codes.
  8. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Two weeks ago I saw with my own eyes 657 for LH exhaust camshaft and 661 for RH exhaust camshaft.
    My mechanic who did the timing with degree wheel and dial gauges insists that this is very good timing...
    Plus if it was timing wrong, car would behave badly all the time, not just when cold..
  9. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Well that is something i was thinking.. already bought cps sensors.. hadn't had time to put them on...
    Was thinking about trying other ECU..
  10. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    Missed the word cold in your post.
  11. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    I'm not a pro.
    What's the data from the upstream sensors when cold? May be able to narrow the bank which is at fault.
    If able to determine bank with fault with o2 data Swap ecu's L-R and see if abnormal data follows ecu.
    Doubt both ecu went bad.
  12. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    Otherwise I'd be thinking what changes when cold?
    What kind of cold? initial start for a minute or 2, or happens until full operating temp.
    Cracked intake manifold
    intake gaskets (replaced already- check nuts not loose.)
    Leaking air plenum gasket.
    Consider Smoke test or ether test
  13. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    753
    Finland
    Mikael E.
    <sarcasm> right? =D
  14. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    I thought so.
  15. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    Now this is the interesting part..
    I start the engine and for 90 seconds it seems to operate very strong (you hear very steady and powerful idle)
    After 90 seconds it seems to to slightly lose its rythem..
    As if it is missing something (slightly rough idle)
    As i start to drive (oil cold) , as i switch to neutral gear (manual) with the car rolling, i try to rev the engine and nothing
    No response
    Just popping / backfire (which i thought was in the exhaust but it is based on mechanic in intake box)
    As it warms up this goes away
    (When cold and stopped, car revs normally)
    Warm the engine underperforms and rough idle (almost dies ) when coming to stop
    Yesterday did compression test 180 and 175 psi right / left bank all cylinders
  16. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    So it's not just when cold.
  17. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
  18. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    MD, after some looking you have have been having similar problems with this car for many years, and they have not been sorted. You have had many threads here to no avail.
    My advice is bring it to another mechanic. If you post a thread with a request for a mechanic near you I'd bet you will get a recommendation. I don't think this problem(s) will ever be found by posting for advice here.
  19. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    You are right! That's exactly what i did!
    The new mechanic first checked if the center intake manifold works ok..
    Next performed compression test if there is any bent valve.. 175-180 psi all cylinders ok
    Finally he tried a pair of borrowed throttle bodies.. no change
    Now he suggests we check timing the proper (difficult way)
    Or find a pair of ECU to check..
    That's why i hijaked this thread to find out more about ECU.. help thanks!
  20. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    Checking how close timing is is not difficult.
    Take off the cam inspection covers (aft of engine).
    put the engine at TDC for cylinder #1 intake phase using piston stop method.
    Check the timing marks through the cam inspection cover. I used my kids play-doh to take an impression of the scribed marks on the cam and the reference mark.
    I know these marks are not always perfect, but if it is close to where Angelo had it when it left the ferrari factory then your problem is not timing.
    Cost will be like 20 bucks for inspection cover gaskets and labor.
  21. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,436
    On the Limit
    Dino
    It is possible to reprogram these ECU's with your car's data, without a 'bend over and grab your ankles' visit to the dealer. It is also possible to use what is essentially the same ECU from any variety of Alfas and Fiats.
    360Trev did this on my car with some very inexpensive tools, a laptop and a wire harness that he put together. We downloaded the files from one of my ECU's and put it on another Bosch ECU and the car ran!
    Earlier in this thread there was talk about the 'master/slave' relationship. The right ECU (passenger) is the master. It interacts with that little devil, the immobilizer which links to the right ECU.
    Once the right ECU is bound to that immobilizer, they are connected for good. One would have to virginize or get a fresh or left ECU to replace that side.
    There is a company in Florida called ECU doctors that can figure all this out for you. You would have to pull the ECU's and send them over. I would start with a phone call to them. They are very helpful.
  22. MD355
    Mar 8, 2004
    802
    Athens, Greece
    MD
    With my new mechanic we decided to check the timing first (check if my old mechanic got it 100% right)
    Next we deal with ECU...
    Anyone that has had a failed ECU can explain the symptoms when an ECU fails ?
    Maybe 1 cylinder bank not working, CEL light, etc etc ?
  23. 360+Volt=Prius
    1,762
    Western Mass
    Raimondo
    Seen post #36
  24. Sloper
    Sloper Rookie
    Jun 30, 2016
    12
    #49 Sloper, Jul 14, 2017
    MD355,
    There are many factors that can cause an ECU to go bad.
    The ECU's on a 360 very different than most control units because they use a hybrid circuit design. See attachments.
    This design is very reliable so what tends to go bad in these units is the software more than anything else.
    Swapping ECU's from one side to the other helps diagnose these issues because if the problems moves from one bank to the other, you know that you have a bad ECU.
    At that point the only solution would be to program a different control unit using the software from the good ECU.
  25. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    655
    Guys, sorry to resurrect an old thread but for some reason my Right side Motronic ECU does not show up (or lists as abnormal, absent, etc.) in a system scan. Yet the car runs fine. A while ago it was still abnormal but had some immobilizer code present.
    Car was not touched for any ECU programming, swapping, updates, etc...the only thing that was done at some point was to replace the alarm 'siren' so nothing to do with imobilizer/etc.?
    Thoughts on how this may have happened? The car runs fine.
