Can I use a hotsy on my 328 lower engine bay? | FerrariChat
Discussion in '308/328' started by qedqeq, Feb 16, 2017.
  1. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    Hey All
    Just wondering if I can use a hotsy pressure steam washer underneath the engine bay.
    I would like to remove years of gunk and that no one cleaned under there when the CV boots separated.
    If so, any areas to avoid?
    Plan on using it from the exhaust mainfolds and lower, transmission, CV shafts, a-arms, rear brake assemblies, and general frame areas.
    I have tried by hand to remove gunk from the underside, and it is depressing when all the time, and it almost looks like I didn't even touch it.
    Regards
  2. Rifledriver
    37,122
    If you don't mind timing belt tensioner bearing failures, water pump and water pump belt tensioner bearing failures, Speedo sensor failures, clutch actuation lubrication related issues, water inside your new CV joint grease go right ahead.
  3. qedqeq
    Apr 15, 2015
    384
    LOLOL, I guess that I won't be doing it then, back to the drawing board
    Thanks,
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,349
    Dumpster Fire #31
    SMG
    True if left alone to drip dry..
    I have steam cleaned the engine bay a couple times, of course it's also followed up by stripping down and servicing, I hate working on greasy stuff. Oil is more damaging to rubber then water oddly enough. True steam cleaning is better then high pressure hot water, but not usually available to the DIY, it's more industrial.
  5. Rifledriver
    37,122
    If you are going to take it all apart its ok if done very carefully but not just for a cleanup.
  6. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    I just cleaned 40 years of oil-soaked crud and gunk off of my engine any engine bay, where all my seals had failed and leaked, and there had been an exhaust fire. Here's my cleaners list:
    For chassis/frame members: Hot water with dawn dish soap, followed by Scrubbing Bubbles
    For engine block dirt: Scrubbing Bubbles
    Engine block sludge/grime: Gunk Engine degreaser GEL, or Penetrating oil (just a small patch at a time), then hot water with dawn, then Scrubbing Bubbles
    Cast pieces, such as bell housing and diff cover: I used etching magnesium wheel cleaner, which DOES etch the surface of the metal, but turns it the same color as the rest of the block, which I found pleasing.
    Most-difficult grime, such as clutch dust: Brake cleaner
    An pilot/aircraft enthusiast friend of mine told me about Scrubbing Bubbles for an aluminum engine, and it works REALLY well.
    Work in small areas and dry everything thoroughly as you go.
  7. jgriff
    jgriff Formula 3
    Jun 16, 2008
    1,125
    Houston, TX
    Wow, someone who took an experts advice and didn't argue. Good on you. This may be a first. :)
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    #8 miketuason, Feb 16, 2017
    I've been doing it for years 35 years to be exact without any issue. If you're careful and know all the critical parts or area that doesn't need to get wet then then you'll be fine. I usually start by spraying Gunk degreaser on areas that are greasy, grimy and oily then let it sit for a couple of minutes the high pressure wash everything that has the degreaser and the results are almost spotless and very clean.
