Can someone clear up a fluid question for me? | FerrariChat
Discussion in '348/355' started by gobble, May 18, 2015.
  1. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    My 355 uses Shell Donax fluid in the F1 hydraulic system. My Gallardo uses Tutela CS fluid in the eGear hydraulic system.
    I'm trying to find Tutela CS as I have a small leak in an eGear line and need to replace that line. It's hard to find in the US.
    I believe Shell Donax is described as an ATF fluid and I used the Mercedes ATF fluid in the Ferrari based on the advice of someone here who compared the specs. I could use that same fluid in the Lamborghini but to be honest I care a little bit more about the Lamborghini and am more cautious about mixing the fluids.
    I was told by a vendor that the Audi part G052171A2 is a direct replacement for Tutela CS, but if you look at the description of that fluid, it says manual transmission oil. That can't be right.
    Does anyone here know if Tutela CS is the same as Shell Donax which is essentially the same as the Mercedes fluid?
  2. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Nevermind. I'm just going to order the right stuff from AMH although I'm still curious about the answer.
  3. Skippr1999
    Skippr1999 F1 Rookie
    4,520
    I use redline D4 in my F1 ferraris. Rifle Driver suggested it which I appreciated very much since it had seemed like a mystery prior to that.
