430 - Can someone confirm I'm not crazy: "soft" clutch reset | Page 2 | FerrariChat
430 Can someone confirm I'm not crazy: "soft" clutch reset
Discussion in '360/430' started by Scottslaw, Dec 6, 2023.
  1. AandSC
    AandSC Formula Junior
    925
    Jax, FL
    Allen
    Here’s a pic of the last 8 years’ clutch wear readings for my very late 08 using a Launch Pro S Mini since 2020. I’ve been using it for the past four years and it’s been very consistent with the previous owner’s indy, although I agree not 100% as you can see by this year’s reading vs last year’s. Maybe I’m misinterpreting what you are saying but the Launch does read the clutch wear on 08s.
    colorfull likes this.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    I am not sure adjusting the PIS was really the issue .. especially you say slipping out of gear ( the PIS is important for changing gears / setting off)
    Making it more loose is my mind counter what I would do - hmm - interesting
    Slipping out of gear - usually worn clutch, worn solenoids , or bad actuator grid ( needs a relearn) - not usually a PIS issue
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    #28 flash32, Dec 7, 2023
    Not sure if you were responding to Corey or me or both .. I said the clutch wear index does not appear on any diag tool after 2007 as pre my explanation above
    I can't remember looking at clutch wear parameter on a 2008 - I always do the calculation as Corey mentioned above and not trust software to calculate
  4. Plainview
    Plainview Karting
    Aug 21, 2011
    95
    Dublin
    oh god - that's concerning! they are the only dealer in my country - so not much alternative but to use them, but they don't generally inspire confidence ...
    can I do the actuator relearn with an OBD tool or do they need to do it at the dealer?
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    You can do a relearn with your tool .. but I would recommend taking a print out of all the data items in the TCU data stream before and after to see if anything changed in positions
    on a cold transmission - just put tin neutral release brake and run self-learn - key on engine off
    cavlino and Plainview like this.
  6. Plainview
    Plainview Karting
    Aug 21, 2011
    95
    Dublin
    great stuff, thanks so much Flash - and apols for somewhat derailing the thread ;)
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    Never let your battery voltage drop below 12v on the re-learn. It is the riskiest procedure in the TCU.
  8. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Speaking of Batteries which ones are people using? It seems very important to run a high quality batter in most late model cars.
  9. CoreyNJ
    CoreyNJ Formula 3
    2,379
    New Jersey Shore
    I have an optima red now, but when it goes I'm going Antigravity lithium because it always keeps a reserve and is much lighter. Will just need a new CTEK battery maintainer to use it, but I already have the adapter to fit the factory plug.
    Mario Andretti and cavlino like this.
  10. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Much much smaller tech LOL but I went with Lithium on my Golf Cart (Camp Ground Use) too to avoid having to be concerned with Charging it over the Winter.
    My Ducati also has Lithium, again great for low maint, zero concerns.
    Do they cost more, oh yea but well worth it!
    I have a couple of Lithium chargers already and if/when I get a Ferrari again in my Garage I will replace the Batter in it soon then later if it shows any sign of weakness since it helps you avoid so many little issues that can be very annoying and frustrating.
  11. Scottslaw
    Scottslaw Formula Junior
    You guys are killing me LOL! Love this discussion (and please continue it...I'm learning alot), but can someone please pull the dang paddles to at least to see what happens LOL?
    Skippr1999, Plainview and cavlino like this.
  12. Mario Andretti
    Mario Andretti Formula 3
    1,752
    Boston
    cavlino likes this.
  13. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Sorry for the sidebar Scott :)
    I suspect there aren't as many 2008-2009 F430 folks on here as 2005-2007 and your scenario would be best compared against the 2008-2009 model years.
    Hopefully someone that has one of those (2008-2009) model years lives in a non-snow covered part of the Country so they can enlighten us on their results.
  14. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    I always felt that it was introducing a temporary error state. I didn't notice any kind of difference afterwards.
  15. Mario Andretti
    1,752
    Boston
    #40 Mario Andretti, Dec 8, 2023
    I did the procedure just now; and it came back with a beep and "1" for first gear in the selector with AUTO at bottom, and disappeared once I released, and I engaged 1st and got going. Seat of the pants feeling... it seemed the engagement was much quicker and less slipping ? I mean the time from car started moving from moment I felt the clutch fully engaged was much less.... Took off with medium throttle like I do all the time.
    Drove well after that, changes were very smooth.
    I did record the values @flash32 mentioned before and after, not much changed
    EDIT: actually, clutch wear changed from 13.95% to 14.58%, all else stayed the same.
    Oil leak with Clutch electrovalve on 25.80 cc/min
    Oil leak with clutch electrovalve off 9.6 cc/min
    Clutch wear index 603
    Clutch pressure plate travel : 0.54 inch
    PIS : 4.12
    flash32 and cavlino like this.
  16. Mario Andretti
    1,752
    Boston
    I did a pis reset recently, thats why my wear index is so low... It will go up and stabilize in under 2000 somewhere in time (on my car).
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    You should always reset the clutch wear index when changing PIS
    cavlino likes this.
  18. CoreyNJ
    CoreyNJ Formula 3
    2,379
    New Jersey Shore
    On my 2009 I haven’t done it in a while but don’t know if it’s a sugar pill or not but it does seem crisper. The procedure I used was to pull and hold the paddles till it beeps then turn the car off. Next time I start and drive off it feels better.
    cavlino likes this.
  19. Mario Andretti
    1,752
    Boston
    I think I did ? Does it go from 0 up, or it goes down from 4000, can't remember.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    It starts from 4000 upon reset and goes up or down depending on tightness and driving style
    I like to see mid to upper 2k for typical city cycle ..with shifting and stop and goes
    cavlino likes this.
  21. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    A lot of great information sharing going on, this community is fantastic
    Plainview likes this.
  22. Skippr1999
    Skippr1999 F1 Rookie
    4,480
    There is definitely something to this.
    Took the Challenge Stradale out for a drive this morning. After warming the car up, I remembered this thread.
    I held the paddles back at the same time on my CS and after about 10 seconds there was a loud “beep” and a “clunk” back at the transmission. Similar trannny sound as when running the re-alignment program using a SD on a 355. I’ve never run that program on the CS, but I guess there’s a similar one.
    There was a substantial difference when taking off from a stand still. The clutch slippage was dramatically reduced after this process and overall shifting seemed more smooth and direct. The CS F1 is always a bit brutal (charming character) but I believe there was a difference.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    Would been great to see if Clutch Wear index changed, solenoid leakage or any engagement/selection threshold changed after you did it
  24. Skippr1999
    4,480
    Can’t help you there, but the beep and then movement in the transmission means something was going on.
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,689
    Central NJ
    Dominick
    Do you have a launch or thinkdiag or ap200
