458 - Can someone explain the stock 458 Valve operation, installing a Forza controller! | Page 2 | FerrariChat
458 Can someone explain the stock 458 Valve operation, installing a Forza controller!
Discussion in '458 Italia/488/F8' started by s4play, Mar 29, 2020.
  1. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,175
    Todd
    My controller was installed by taking the airbox off only
    That gave the tech enough access to do the job
  2. Beez
    Beez Karting
    May 22, 2016
    111
    But is yours Italia or Spider? My understanding is the working areas are not the same.
  3. todd cloud
    Jun 21, 2019
    1,175
    Todd
    Italia. I see now how this would not work on a Spider.
  4. 458SG
    458SG Rookie
    Oct 17, 2021
    19
    Singapore
    Vipula
    For anyone still considering the job, here's a quick video I shot for my Italia. Didn't have to remove the rear bumper and everything works perfectly.
    cosmotron likes this.
  5. Snapshift
    Snapshift Formula Junior
    944
    Centralia IL
    Lyle D. Pahnke
  6. Beez
    Beez Karting
    May 22, 2016
    111
    Great to have a new video specific to a Spider, thanks!!. This thread now has 3 confirmations of being able to do the job on a Spider w/o bumper removal. However I suspect it is possible that removing the bumper might still be a smoother process. Maybe it's a six-of-one vs half-dozen of other situation. I need to get around to this soon.
  7. Mafiaboy1975
    Mafiaboy1975 Formula Junior
    Aug 10, 2019
    261
    South Africa
    Mick
    You can loosen the air box on a spider and shift it slightly to get access to it. It’s a 30min job.
    I recently installed Larini club sport cats and there entire job took me 2 hours. All done from the top of the engine bay.
    I’m probably faster as I know where everything is given I have worked on the car many times.
    The only time I took the bumper cover off was to take the original exhaust out as it’s huge and was stuck together. After that the Capristo exhaust that I installed can come out without removal of the bumper cover.
  8. 458Silverstone
    Jun 25, 2023
    24
    A Youtube video shows you can disconnect and plug the single vacuum line that goes to the solenoid before it splits to the valves and get the valves to stay open all the time. Does anybody know the approximate inside diameter of that line? I am considering putting a ball valve in that line, so the ball valve can be closed to run the exhaust valves open all the time, or the inline ball valve opened if somebody wanted the stock exhaust operation.
  9. Beez
    Beez Karting
    May 22, 2016
    111
    Could you pls link this particular video? Thx!
  10. 458Silverstone
    Jun 25, 2023
    24
    Beez likes this.
  11. Beez
    Beez Karting
    May 22, 2016
    111
    You are probably well past needing this info now, but thought I'd answer while I'm amidst doing the same thing. ID of that line is 4 mm.
    458Silverstone likes this.
  12. tubedreamer
    tubedreamer Rookie
    Jan 13, 2022
    44
    Spent several hours trying to remove those hose clamps from hell to remove the plug for the valves to restore to stock connection. Just did everything without lifting the car. (Valves were plugged/ always open). drone from being always open was killing me. I couldn’t even cut the crimp with tin snips, it just squeeze between the blades. No hope at all for any of those little pliers/bullnose cutters.
  13. Snapshift
    944
    Centralia IL
    Lyle D. Pahnke
    If you can get or borrow a pex tubing crimping tool, they will cut off the oetiker clamps with ease. Just cut across the crimp ears and set the crimper to cutting. You can reinstall the clamps with the pex tubing crimper as well.
  14. Vegas CS
    Vegas CS Formula 3
    1,236
    Vegas
    James
    To revive an old revived thread…..I just did the valve unplug thing yesterday. Most people say to unplug at the valve but, instead, you can just disconnect and plug the hose that is in the middle, connected to a hard vacuum line. That hose the splits to the individual valves. Cuts a simple job in half.
    After having the valves open all the time now is great for short trips. I’ll be installing the Forza controller before I make any journeys longer than 200 miles though.
  15. Snapshift
    944
    Centralia IL
    Lyle D. Pahnke
    The properly installed Forza give you 3 selections regarding valve control.1, computer controls valves, as designed open around 4K RPM. 2, always open no matter speed. 3, always closed no matter the speed.
  16. dustman
    dustman F1 World Champ
    11,703
    Id like to install the controller but not take off the rear bumper.
  17. Snapshift
    944
    Centralia IL
    Lyle D. Pahnke
