Can you buy a replacement solenoid for the master brake cylinder? | FerrariChat
Discussion in '348/355' started by buddyg, Jan 4, 2017.
  1. buddyg
    buddyg F1 Veteran
    6,303
    Naples, FL
    Buddy
    So I have 1 bad solenoid in the master brake cylinder. Ferrari doesn't sell them individually only the whole kit. That's like $6000.00 no thanks.
    My shop says if we could located a new solenoid he could repair the current master brake cylinder using the new solenoid.
    This is a TEVES ATE, anyone have thoughts or ideas?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    That system was used on other cars as well. I'd suggest you contact Ferrparts and see if they have used parts.
  3. buddyg
    buddyg F1 Veteran
    6,303
    Naples, FL
    Buddy
    I got a new unit from Daniel at Ricambi America for 60% off what Ferrari wanted.
    Thanks Daniel!!
  4. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Great result Buddy. Good on Daniel as usual.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,231
    Serbia - Niš
    Miroljub Stojanovic
    I presume you mean one of the solenoids inside the rectangular ABS block. You will not find these separately. Jaguar has the complete Ate ABS block available separately (separate from the whole master cylinder assembly). This unit looks exactly the same as the Ferrari one and, according to my resistance measurements, its solenoids inside are the same as what Ferrari ABS has. However, I cannot confirm that Jag ABS can be a straight replacement. Alternatively, you can look for a used Ate ABS Block or a complete Jag Ate MC (I saw a number on Ebay) and use it for parts. A lot of info at http://www.ferrarichat.com/forum/348-355-sponsored-bradan/516911-348-master-cylinder-abs.html.
  6. buddyg
    buddyg F1 Veteran
    6,303
    Naples, FL
    Buddy
    New Master Cylinder Kit
