Can you have 2 wireless routers on the same system? | FerrariChat
Discussion in 'Technology' started by UroTrash, Oct 18, 2009.
  1. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    I'm redoing an old house. I'm going to have a wireless router off of either cable or off of DSL.
    I'm also going to run an RJ45 cable out to the apartment I'm building behind the house, ~150 feet.
    2 questions.
    1. Is there a limit to how far you can run RJ45 cable?
    2. Can you put a second wireless router in the apartment (first being in the main house)?
    I'm trying to not have to pay for DSL twice.
  2. jmm
    jmm Formula 3
    1,024
    Dallas Texas
    Jim
    I use Apple Airport routers. There are four in a rather long, two-story house — one at each end on each floor. This is because there is a lot of steel in the framework of the house and that tends to interfere with the signal. One is designated the "master" and the other three are slaved to it. It works perfectly, with transparent hand off of one to the other as you move around. Because of the steel framework, the metal roof and metallic film on the windows, I had to put up a cell-phone antenna on the outside of the house and a repeater inside the house to amplify the cell signal to "more bars in more places" status. All problems have solutions. Only one of the Airports is connected by land line to the internet.
  3. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,272
    Seattle Area
    Dave
    100 meters (~300 feet) before you have to hit a router.
    Yes - just set up the second router (or 3rd or 4th for that matter) in 'repeater' mode
    linked to the main router. That's how my house is set up. I have 1 main router with
    2 repeater routers to cover the whole house and deck.
    Jedi
  4. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    Not all routers have any option for repeater or access point mode so do your homework before you buy! The Apple Airports sure do make life easy compared to some of the junk out there from Netgear, DLink, et al.
    As for the limits on ethernet - the standard is 100m as posted above but longer will work especially if the cable is properly terminated and of high quality to begin with. I know of installations (not mine I hasten to add!) with runs of over 700'.
  5. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    Thanks fellas! As usual, question answered quickly!
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Our office is about 300 ft away so we're using two wireless access points with wireless routers at each end. The access points only communicate with each other forming a "virtual" wire. It works perfect.
    http://www.linksysbycisco.com/US/en/products/WAP54G
  7. mike2009
    mike2009 Rookie
    Feb 18, 2006
    5
    London
    if your outbuilding is on the same power grid as the main house, have a look into 'homeplugs'.
    If you want to take the path of 2 routers, then try look at units that run Linux, i.e. Linksys WRT54GL. You can load 3rd party firmware that allow you to control things like, signal strength, priority, QoS, static IP's, etc.
    this forum is helpful...
    http://www.linksysinfo.org/forums/forumdisplay.php?f=160
    possible scenarios,
    House: WRT54GL + homeplug
    Outbuilding: homeplug + 8 port switch
    or
    House: WRT54GL
    Outbuilding: WRT54GL in repeater mode
  8. jimpo1
    jimpo1 Two Time F1 World Champ
    Jul 30, 2001
    24,905
    Dallas, TX
    Jim E
