Can you help with mystery wire harness? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by dstacy, Aug 27, 2007.
  1. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    #1 dstacy, Aug 27, 2007
    In advance I REALLY appreciate anyone who wouldn't mind taking 5 minutes to help me out on this one.
    Series 2 car, 1984.
    I removed the air intake hose feeding the air filter on the right side of the engine. It only took a couple of seconds, easy to do. Under that hose I see a factory wire harness that isn't connected. Its just laying there. Look at the picture (you're looking forward). Where the first arrow is pointing you can see where it exits the main harnes. It looks to me like it should go forward (I really don't know) but whoever disconnected it bent it back to hide under the intake hose. At the end it has a white connector. The connector has 6 open slots, however only 5 of them are used. I'm trying to figure out where this is supposed to go.
    Any help?
  2. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Dave,
    By the shape of that boot, it appears that it originally went to the electronic ignition unit. Since it is disconnected and your car is still running (I assume), you must have a MSD or similar box installed elsewhere. If all is true thus far, then, (a) check the wires w/in boot to confirm codes below and (b) check yellow wire (w/ignition sw. 'on') for +12V. ( if so, you should protect that connector (shrink tube or similar) to prevent a short due to moisture (or whatever).
    If car is not running, reconnect 'boot' connector to underside of electronic ignition unit.
    Pin 1--green(terminal R1 of distubutor--lower side area towards clutch housing)
    Pin 2--black(ground @ distributor)
    Pin 3--red(terminal k of coil)
    Pin 4--not used
    Pin 5--red(to tachometer--thru fuse box)
    Pin 6--yellow(ignition sw.)
    Bruce
  3. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    :eek: DUH!!!!!!!! OF COURSE!
    What an idiot I am. Thats exactly what it is. Oh crap I feel stupid. :eek:
    Hey Rob, can we somehow delete this thread so nobody will know what a dunce I was today.
  4. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Too late :p:D
  6. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    Oh sure laugh it up at my expense Pap.
    <groan> oh this thread is going to haunt me. If the winery becomes a sponsor, I wonder if I can get this thread pulled.
  7. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,240
    MA
    Don't worry, Dave, we've all done similar things at some point in our lives. Just don't quit your day job! ;-)
  8. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #8 350HPMondial, Aug 28, 2007
  9. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Dave, they're really not going to let this thing go-----you might hit an all time high on 'views'. Better set up your sponsorship NOW!
