Can You Jack Front and Rear with 1 Jack Point? | FerrariChat
Discussion in 'Technical Q&A' started by UroTrash, Aug 16, 2009.
  1. UroTrash
    Jan 20, 2004
    40,688
    Purgatory
    Clifford Gunboat
    If you have a car that is short and stiff like a GTI or a Civic, is it bad to jack only one of the jack points, either front or rear in order to lift both tires off the ground for a tire rotation?
    I've always done this on cars that seemed "comfortable" with it, but I get the inpression from a Porsche forum that it torques the chassis too much and is bad for a car.
  2. Steve Magnusson
    26,932
    I think it depends on the model/design of the car -- e.g., my wife's Subaru has manufacturer recommended front and rear center jacking points, but I wouldn't pick up a 308 by using the middle of the small rear crossmember.
  3. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #3 finnerty, Aug 16, 2009
    Another concern is safety / stability. If a manufacturer has specified a center jacking point, then you know the vehicle can be safely balanced about that point when jacking. Otherwise, a given chassis may be stiff enough to center jack, but not necessarily stable ---- which could be dangerous to whomever / whatever is under the vehicle.
    Other than the Subaru example given, I have only heard of certain makes of pick-up trucks being designed for safe center jacking --- and only the rear end via jacking under the rear differential.
  4. UroTrash
    Jan 20, 2004
    40,688
    Purgatory
    Clifford Gunboat
    This isn't a center jack point.
    These cars have a spot just aft of the front tire and just in front of the rear.
    I noticed that when I jacked the GTI up to rotate the tires (beginning in the front), the rear tire was clear of the ground as well! So I figured: why use 2 jacks?
    No one is under the car, just for tire rotation.
  5. BOKelley
    BOKelley Formula 3
    2,397
    Au'n Colorado
    Brock
    After examining the crossmembers of my Mondial, I decided that it would be unwise to jack up the front and then the rear from central points. Thus I have resorted to using two floor jacks, one on either side, to first jack up the front and then the rear to get the car up on four jack stands.
    I think it is time to start looking for a car lift to install in the garage.......
    Brock
  6. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I agree. If, when the car is lifted at a designated jacking point, and the whole side lifts enough to raise both tires of the ground, what's the harm. I'd still put a jack stand under there somewhere.
  7. finnerty
    May 18, 2004
    10,406
    #7 finnerty, Aug 17, 2009
    We are not talking about the same idea. "Center point" can mean either the mid-point of a side (left / right) or of an end (front / back). I'm referring to single (center) point lifting of a vehicle's end (front / back) not a side. Single point side lifting is much more stable than single point end lifting.
    In fact, for purposes of tire changing only, the 308 has a single jacking point on the car's side under the trailing edge of each door ----- when using the factory supplied jack in this location, you will pick up the entire side (both front and rear wheels) of the car. But, I would never recommend trying to pick up the front or rear end of a 308 from any single point in similar fashion or with any other jacking equipment.
  8. DGS
    DGS Seven Time F1 World Champ
    73,017
    MidTN
    DGS
    #8 DGS, Aug 17, 2009
    Quite ;)
    (Although side lifting to weld the fuel tank may not be a great idea.)
    (But it's even worse to try to weld a fuel line from inside a service pit.)
    If you're the type to actually rotate your tires, you'll probably want to consider a floor lift. You can get a portable low-rise lift that doesn't require any special installation, doesn't overload the floor, and is ideal for rotating tires, swapping summer/winter wheels, oil changes, or just picking the car up to make it easier to wax the lower quarters. ;)
    (Remember: with radials, you only rotate front to rear, not side to side. I remember reading that it's bad to reverse even radials that aren't directional treads.)
  9. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    "(Remember: with radials, you only rotate front to rear, not side to side. I remember reading that it's bad to reverse even radials that aren't directional treads.)"
    I don't think so. The manuals that come with my "day-to-day" cars, illustrate rotating radials by Fronts to rear on the same side, Rears cross over to fronts.
    "Directionals", of course, stay on the same side.
  10. UroTrash
    Jan 20, 2004
    40,688
    Purgatory
    Clifford Gunboat
    Thats what I've always seen.
    What kind of car is that?
  11. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I read the "don't reverse rotation" issue only applied to the very earliest radials in the 1960's. Modern radials won't be harmed by reversing rotation.
