Buy
Can you remove a 308 GTSi gas tank with engine in place ?
Discussion in '308/328' started by andy2175m4@yahoo.com, Oct 27, 2009.
  1. andy2175m4@yahoo.com
    andy2175m4@yahoo.com Formula Junior
    Dec 7, 2008
    467
    Los Angeles, CA
    Andy Rein
    Another logistical question: My much-bondo'd 308 appears to have a crumpled gas tank on the passenger side of the engine, and my question is: Can this gas tank be removed without pulling the engine ? This crumpled gas tank does not leak at all, and the crumpled area probably reduced the capacity by less the 15% so it's debatable if it's even worth fiddling with, but nonetheless, if anyone has a clue how to remove it it would like to hear.
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    1,997
    Kingsport, TN
    Lawrence A. Coppari
    I could tell you how to do it with a 328 which is similar but the devil is probably in the details. My 328 tank comes out with removal of some coolant plumbing and the rear passenger side brake rotor. It's a PITA.
  4. Glassman
    Glassman F1 World Champ
    Just about the same for a 308.
  5. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,183
    Snohomish, WA
    Eric L
    I just RR'd the tanks on my GTS and I don't think there is a difference in the GTSi. Once you remove the A/C compressor and remove the tank straps and hoses, you should be able to sneak it out. It's tricky, and you'll need to turn the tank to get it between the brake rotor and the wheelwell lip.
    If you're looking to un-crumple the tank, you may be able to do it by fitting a compressed air hose onto the crossover tube hole, sealing the others and slowly filling with air. Depending on how badly it's crumpled, the pressure may pop it back into shape. I've seen marginal success with this on motorcycle tanks and YMMV.
  6. enzoferrariphil
    enzoferrariphil Karting
    Oct 26, 2004
    67
    Solana Beach CA.
    Philip Ponzio
    Had a leak on my 1980 308 GTSI on the drivers side.I had to remove the rear a-arms and brake components. never done passengers side.should be the same .
    Phil
  8. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    I have had the Pass side tank out of my '79 308GTB. Needed to remove AC, many hoses and straps. Did not need to remove brake rotor or control arm. Driverside would not come out this easily. You will need to turn the tank around and snake it out.
  9. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    2,531
    I had to remove both of mine. Engine stays in. If gasoline (in any quantity) wasn't involved, it wouldn't call it a terrible job.
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,192
    Seattle, Washington
    Cliff
    #8 CliffBeer, Mar 1, 2011
  11. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    With the left tank out, looks like a good time to change the fuel filter and change every hose in sight.
