Can you run steel rotors in front and ceramic in rear? | FerrariChat
Discussion in 'Technical Q&A' started by raminjulian, Mar 13, 2022.
  1. raminjulian
    raminjulian Rookie
    Feb 26, 2022
    8
    Julian Yu
    I have a cracked ccm rotor in the front I was considering instead of replacing a single rotor can I convert both front to steel and leave the rears ceramic? Let me know thank you guys
  2. Twosherpaz
    Twosherpaz Formula Junior
    Feb 25, 2014
    943
    Thermal, CA
    Private
    I’m no expert but that sounds dangerous. You would have two different types of brakes occurring simultaneously.
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,216
    Georgia
    Wade Williams
    While I am sure you can do that, I expect the ABS to be effected in a way that might cause issues. I would not recommend doing that at all. Just put steel brakes on all four wheels.
    V4NG0, tbakowsky and JL350 like this.
  4. windsock
    windsock Formula 3
    1,150
    Putting high quality steel brakes front and rear on that car is like $6-$7k not sure why you would only consider doing half.
  5. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Is this just to save money?
    Matt
  6. INRange
    INRange F1 World Champ
    12,526
    Virginia/Florida/Caymans
    JD
    I’m not sure this is a good idea under any circumstances. The braking system was designed with extreme conditions in mind.
    Why do you think the front rotor cracked?
  7. tazandjan
    39,159
    Works fine the other way around (ceramic front, steel rear) since I and a couple others had that set-up for a few years, but not with the CCMs on the back.
    Rifledriver likes this.
  8. Rifledriver
    37,082
    Cold the car can handle it. Ferrari bragged at 360 school with modern brake systems you could put 4 different brakes on the car and it would stop fine.
    But as they got heat in them the fronts would be losing effectiveness and the rears increasing. I really don't think its a good idea.
    V4NG0 likes this.
